Question about Whirlpool Heating & Cooling
Whirlpool air cond model acm122xj1
Put away last year and when reinstalled this year and plugged in, nothing happened. do have electric to outlet
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
SOURCE: Year old Frigidair Air Cond.
I think I get a "bug" or "animal" in my unit every once in a while, that gets caught in the fan and thrown around for a few minutes. It makes a clunking noise, as you say. Maybe???
Posted on Jun 05, 2008
  • 234 Answers
SOURCE: Craftsman air compressor will not start
I am assuming that there is no air in the machine now. Otherwise it will not turn on if there is enough pressure in the tank.
If it will not start at all, the on/off switch on the pressure switch may not be turned on or it is defective.
You can also check the reset switch on the motor (red button).
These are very simple setups and it shouldn't take too long to troubleshoot.
Posted on Apr 18, 2009
SOURCE: Tomtom 510 will not activate. tried it with
After posting my problem, I did some more browsing and came across this on the amazon webiste:
31 of 32 people found the following review helpful: stars-4-0._v45457020_.gif Cure for not able turn on the Go 510, 16 Jun 2007 By Sirius (Essex) - See all my reviewsI like the tomtom so far the only niggle was it would not turn on once.
No troubleshooting on instructions, found cure on internet,reset button
underside. With the tomtom turned over and the card slot on top right hand
side there is a small rubber foot at the half moon shaped enterance, up at about the 10 o'clock position from the foot,but before the green circuit
board there is a small half round cut out with a hole under you need to press in this hole for a few seconds with a paper clip to reset. I wonder how many people have sent their tomtoms back that would not turn on.
Tried it & worked a treat!!! Newcastle here we come again ...
Posted on May 05, 2009
  • 496 Answers
SOURCE: Yard-man model 12a-979L401 won't start (9 years old)
My dad always taught me, rest his soul, that basic 101, if you have gas getting to spark, SOMETHING out to happen.
I'll ask a series of questions and propose some possible solutions. Hopefully we'll crack this mystery. Warning, this might be a tad lengthy... ha
1. Is the spark plug firing?
To check the coil that sends spark to your spark plug and the plug itself:
You can remove the spark plug from your engine and reconnect it to the spark plug wire while it just lays on your mower. pull the starter rope (make sure you're holding down the kill lever on the handle). Look at your plug end as you pull the rope.
Got spark? If yes, go to the next step, flagged ***. If no, look at the end of your spark plug that would go into the engine. The "L" shaped finger should be gapped from the small circular shape on the plug... this is the "gap". Your manual may provide specs on how wide this gap should be. If there is no gap, your plug won't work properly. The "L" shape is a soft metal and can be bent... create the proper gap. Try the test again to see if the plug is sparking. If not, you may have an issue with your coil.
***Yes to spark. Let's look at the gas issue now. OPTION 1. I will tell you that in my experience, water in gas is a major culprit for a mower not running. You've replaced all the filters... good.
I'm not sure of your mower, but most models have a "bowl" bolted to the bottom of the carburator. Sometimes moisture can get in the gas, get trapped in the bowl and won't go away or won't allow gas to get to the spark. Loosen the bolt... it's ok if gas from the bowl spills from this, the bowl doesn't hold much gas and it won't drain your tank. Plus, this means your carbuator is allowing the gas from the tank to the bowl. As you are looking at the gas spilled on the mower deck, see if there are beads of water in it. As you know, water and gas doesn't mix. This would be a tell tale of the problem. I would carefully remove the bowl from the carb and wipe it dry, then reassemble the bowl.
To be on the for sure side that you have no more water in your system, you could disconnect your fuel line from the gas tank and drain it out. Use a jar or container... you can see water in the bottom of it. You can reuse the gas too... just don't include the water!
OPTION 2. If your carb and tank are now H2O free and you're still getting to results, you may have a clogged jet on your carburator. This little pin-hole passage allows gas to pass through to the spark. Sometimes a mower sitting up a while, can cause a laquer effect to gas and it can block this passage. Removal of the carburator from the engine is required and a simple pin can be pushed through this passage to knock a "plug" out.
Geez I hope I didn't miss anything! ha
Good luck to you... I hope it's a quick and easy fix.
Posted on Aug 26, 2009
Thermal fuse in dryer keeps blowing out
Hi Janet Douglas
Check to make sure your vent is clear, this can cause the overheat problem and blow the thermal fuse.
Also check to make sure the blower is not full of lint also as this can cause the same problem you are having happen.
Another thought:
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element and thermal can burn out very quickly.
Please take time to rate me
Bud
Oct 14, 2012 | Whirlpool Dryers
The ac quit, check all connections not an issue. took off front panel to see where reset fuse located. is there one? whirpool 12k btu 110v model ACM122XJ1 SERIAL# QK2343975 IF THERE IS RESET WHERE...
The easiest way to reset it is turn the unit OFF and unplug it for 10 minutes. Then, plug the unit back in and turn it ON. The 10 minute timeout will allow the electronics to reset and revert back to the original factory settings. If it is able to reset, it will do it then and you can set the controls as you like.
Thanks for choosing FixYa.
Jul 31, 2011 | Whirlpool Heating & Cooling
I have a LG LWHD1500ER window air cond. and am wondering if I can plug it into a plug in my bedroom that has nothing else plugged into it? I don't know what a dedicated circuit means?
When you say dedicated circuit, you should have an electrical outlet that was installed just for your air conditioner. This outlet must have it's own circuit breaker that has higher ampere ratings. This ampere rating must correspond to your air condition horse power (HP) e.g. .75 hp, 1 hp, 1.5 hp, 2 hp. You should consult a qualified electrician for your safety.
Jul 02, 2011 | LG LWHD1500ER Wall/Window Air Conditioner
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No blower on any setting, no air cond. also.
check to see if you have power at wires at blower if u do then replace resister 1 more time but first... put power to blower motor if it comes on replace resister
Jun 25, 2009 | 2003 Dodge Dakota Club Cab
My whirlpool clothes dryer will not start.
Hello Rick,
Use this link to get information for your dryer.. it should provide you with everything you need. Get back to me if you are still having problems..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 28, 2008 | Whirlpool Dryers
Heating & Cooling Logo
43 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
