Question about Soyo DYLTO32A 32 in. HD-Ready LCD Television
Green scrolling bars?
I have had this TV for years with no problems.  today I turn it on and there are these green bars that scroll from top to bottom and are the full width of the picture....
any ideas as to what the problem is?
    Problem Solver:
  • 5 Answers
I have the same problem and was told over the phone by a repair facility that the LCD screen is going bad. My tv has done this since i bought it and smacking the back of it with my hand stopped it til now.
Posted on Aug 13, 2009
Scrolling ghost bar on Samsung LCD TV
Majority of the time when you get a soft type of scrolling or distortion it is a poorly made cable or connector causing bad signal. I would replace that RCA cord altogether and go to the top end with and HDMI cable. If this is not an option buy a newer upgraded version of the RCA cable. The ones that come with everything are only really good for in a pinch
Jan 29, 2014 | Samsung Silver Tilt/Tilting Wall Mount...
Green line from top to bottom on right hand side of tv
I am assuming that this is a green bar and you are connecting your cable box to your tv with an hdmi cable. If this is true you need to walk over to the cable box and turn the power off (not with any remote control but directly on the unit). Next press the menu button that is on the unit. The hidden menu will come up on the screen. You will see Color System as one of the menu options and you can use your remote control or the down arrow on the front of the cable box to scroll down to Color System. Next use the right arrow or the left arrow to change it from YCC 4:4:4 to RGB or vice versa. Then turn on the cable box and voila the green bar should be gone.
Jun 14, 2010 | Televison & Video
Scroll bar
Closed captioning? Turn it off either in the TV menu or direct button, or in the cable/sat box menu.
Apr 13, 2010 | Samsung HLN5065W 50" Rear Projection...
How do you view your final destination once you have set a route?
After you touch go and it starts navagating, touch the green bar at the top of the screen. You can scroll through the turn by turn directions. at the bottom you can touch MAP and see the whole route on the map.
Apr 04, 2010 | Garmin nuvi 255W GPS Receiver
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
Autoscroll
Try simply using a system restore to before the problem started acting up. Also, you can try going into the mouse properties (Start Menu, Control Panel for Xp) and look for scrollsettings there, which may allow you to turn off certain mouse features (aka. if gestures are enabled it might be conflicting with scrolling).
Hope this helps.
Dec 16, 2008 | Gateway MX6920 Notebook
Menu will no longer scroll and stop
I removed the cover by following the directions I found through a Google search on the problem. I then removed the rubber pieces attatched to the battery, which is what the scroll pad sit on top of. It was explained that the battery can swell from getting hot and put pressure on the pad causing it to malfunction.Replaced the cover and all is working just like brand new!
Aug 20, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Red and green scrolling bars on my tv
probably the cable box, scrolling bars are a clasic sign of this
Jun 05, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Soyo DYLTO32A 32 in. HD-Ready LCD Television Logo
69 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
