Question about Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television
Lightning strike lightning hit the tree behind my house and now my tv doesnt work. the power light stays on when the tv is plugged in but the tv will not turn on. does this light staying on mean something. Or is my tv a boat anchor
  • bkindle Jun 11, 2008
    no it didnt do anything. It doesnt even look like the screen is on. the tv doesnt make any noise like when you turn it on. the light says timer underneth of it but it is right next to the power button. I assume that is the power light it is always on when the tv is on. the power button wont turn the tv off or on the light just stays on as long as it is plugged in.
  • bkey913 Oct 31, 2008
    I hope you all don't mind my interjection , but I am having the same problem. If the pressing in of the buttons ( remote or on tv itself?), don't work, which fuses are you referring? Thanks in advance for your help!
    Master:
  • 469 Answers
Press menu and input both in together on the front of the TV and hold them both in together for 8 seconds then let me know if the LED blinks a two digit code. Tips To Be Secure Whilst Driving At Evening AmanStino
Posted on Dec 27, 2016
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Mitsubishi Master
  • 1,001 Answers
USB Charger Cable for Apple, Lightning Cable for Apple Amazon com Charm sonic 2Pack 4 9Feet 1 5Meters USB Charger Cable for Apple...
I have an older Mitshubishi vs-60803 (60 inch model. This is a rear projection HDTV ready system that uses an external converter model RGB-cv10 to creeate HDTV. Everything has been working fine until dish satellite told me to push a mode button on the satellite receiver, to reset and size the picture. This worked on another TV that I have. But in the case here, when I try to get the HD picture back, it won't work properly. What I found out is that if I pull out the satellite card, the system recycles. Then, the Mitshubishi converter goes to solid red dot indicating there is a signal. But ten or so seconds after, the tv screen flashes black and you can hear the sound while the screen stays balck with red zigzag lines on the tv screen. Then after another 10 seconds or so, the screen turns blue. In another ten seconds, the words check HDTV RGBHV cables. I have checked cables actually reversed all and can find no cable problems. And during this, the red light on the converter starts flashing red indication no signal. Any Ideas? Is the lack of signal likely due to cable connection or what. Remembrer all worked fine except the picture size until I pushed the mode button on the satellite receiver.
Posted on Jul 08, 2009
  • Mitsubishi Master
  • 8,617 Answers
Posted on Jun 11, 2008
  • Sonny Berry
    Sonny Berry Jun 11, 2008
    I would check the fuses one or two of them may be blown due to the surge of electricity.
What does it mean when one reads FD in the panel and the lights on the panel aren't stable?
The control board to your range may have been damaged because of the lightning storm. It happens when lightning strikes a power line and sends a surge of power to your home. This large current surge can easily damage electronic circuits. More often than not if a device is on and lightning strikes, that is when the device gets damaged. During large lightning storms it is best to turn off all electronic devices. The electricity going to your house is fine now and that is probably what your electrician checked.
Nov 22, 2017 | Kitchen Ranges
Sanyo tv won't turn on after a lightning strike.
Ask friend if broken when given to you. If not I would suspect the power supply is fubar..
Sep 16, 2017 | Sanyo Televison & Video
Will a nearby lightning strike cause a power board failure?
It could happen yes it would depend where the strike entered the TV. Not all lighting strikes hit on the electrical lines, on a TV they can come through the cable, as well as a antenna if you have one hooked up.
May 10, 2014 | Samsung UN32EH4003F
Oven will not light
yes this is most likely do to the lightning i have been to a couple houses hit by lightning that all of the appliances were shorted due to lightning try first unplugging the power cord then replug to see if you can get it to trip back to the normal fuction mode most of the time this does not work most likely your main control board has shorted out due to the lightning most of the time this is covered under you homeowners insurance if you rent then you can speak with the landlord. your other option would be to open the unit and find every shorted spot which might get a bit costly hope this helps
Jul 18, 2010 | Whirlpool Kitchen Ranges
Lightning strike
This model is famous for capacitors being bad in the low voltage regulators on the signal board. Also has been known for cold solder connections in the power supply to the convergence IC. I don't have my notes at home but I belive that model only uses one IC for convergence, STK393-570. You cant see it from the back because of it being hidden by its heat sink.
Jun 23, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Broken TV in building hit by lightning
hi
depending on the intensity of the lightning strike.Your tv may have blown components in the power supply section of the motherboard.
unfortunately its very very difficult to acertain level of damage unless its looked at by a trained tech/engineer
cheers
Jun 16, 2008 | Televison & Video
Lightning strike
Hello bkindle.....not a boat anchor YET!!!! Had similar problem with WS-55513 and it turned out to be a faulty DM board. There are 4 capacitors on the board that may have blown. If yo can solder, it is a pretty easy repair. I purchased a PDF manual for mine online to get familiar with the model.
Otherwise, you can expect to pay between 275.00 for a repaired board OR between 350.00 and 450.00 for a replacement board from Sears or Mitsubishi.
Hope this helps. I know it is frustrating but be patient.
Good Luck - Richard (MetalDad)
email: PentiumDreams@aol.com
Jun 12, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Lightning strike
Lightning hits do some nasty damage to electronics.
Alot of times that type of repair is part of an insurance claim. The insurance company requires estimates and will repair them up to the cost of replacement.
If you arent dealing with an insurance claim on this I'd still recommend a professional estimate.
Lightning damage sometimes is confined to the power supply and once repaired could be fine bit in my experience most items that take a nasty hit are a write off.
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 18, 2007 | TruTech PLV16320 Television
Mitsubishi WS-55315 55" Rear Projection HDTV-Ready Television Logo
382 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
