Question about Minolta Office Equipment & Supplies
Minolta copier SN 312039
It was doing just fine the other day, and all of the sudden, when it finished one small job, it started showing code C0b71. Any idea if I can fix this, or do we set the unit out by the curb? We are non-profit, and cannot afford the $2500 service agreement or the $500 they want up front.
  • Tim Babcock
    Tim Babcock May 11, 2010
    What model number copier is this?
  • Minolta Expert
  • 1,326 Answers
Basicly, a Cob71 deals with the toner bottle. Have you replaced it resently? try to take it out again and let the copier warm up to ready and reinstall the toner bottle back in. See what happens... Also, it helps if we know what mode it is for more info.
Posted on Jun 12, 2008
The solution of error code c0500 in Minolta Dailta Di351
Sir, First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip ever again :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Feb 01, 2015 | Minolta Office Equipment & Supplies
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
Code bizhub c350
Mam,
Open the front door lay down on the floor and look up at the section that is slanted (close to hinge side of the front door) Fine the small hole with the machine on, fine a small non metalic stick and in-cert into the small hole touching the small switch which will re-set the machine for C-0500 codes. Do this once if the code comes back replace the fuser, DO NOT RE-SET again messing with FUSER can catch on fire will ruin a perfectly good day.
Dec 14, 2013 | Konica Minolta DiALTA Di200 Copier
Minolta di2410 c0500 error code
First ensure that the right side cover is closed correctly. Check that the two latches that are on the door are not broken especially the rear one. Then fine a paper clip. With the machine on look on the right side of the control panel you will find a small hole. Place the paper clip inside the hole. (Once that is done you can only use that paper clip for that only :) Copier tech humor!) Watch the screen you might see abort code that OK. When the screen come on that show the copiers look to the left of the screen in the middle a small "." will appears when it does press 3. Nothing is going to happen. Code will come back. Now press the Utility button you should now see a button marked maintenance mode. Press it then press trouble reset. Once again the machine will go though its normal warm up will see the "." do not do anything. Ready to Copy Should appear. If the code comes back do not reset the code your messing with the fuser (The Hot part). It can catch on fire (That would ruin a perfectly good day) so have a technician look at it.
Jan 22, 2013 | Minolta DI2510 Black and White Copier
A MALFUNCTION WAS DETECTED - CODE C0500
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Minolta Di3510 All-In-One Laser Printer
Minolta Bizhub C253 - C-11C3 finisher error
The 11XX code refer to the printer and hard .To reset push the reset button or open the front door and close.
Dec 11, 2009 | Konica Minolta Office Equipment & Supplies
Bizhub Konica Minolta - Error Code C1183
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.
Jun 07, 2008 | Minolta bizhub 200 All-In-One Printer
29 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
