Question about Kenmore Washing Machines
My washer just stopped spin but it fills up with the water but it stopped turning just 5 mins a go..
    Genius:
  • 1,073 Answers
What is the model number for more help
Posted on Jun 10, 2008
GE WWSE5200B1WW Top Load washer will not fill or agitate
Hi Scoti
I would start with water level pressure switch. It regulates how much water goes into washer and also stops overfilling..It may be defective and thinks washer is already full( hence no water and automatic drain spin) P#WH12X10093
Second thing to try is unplugging the washer for 15 min and letting all the voltage leave the control board. At this time you will reset the washer to default factory settings in case there was a computer glitch..
Good Luck
Jul 04, 2017 | GE Washing Machines
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Kenmore 90 Series fills with water but would not agitate or spin
You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
Best of luck!
Jul 14, 2009 | Kenmore 22422 Top Load Washer
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Washer calypso
Unplug your machine for 5 min then turn on spin to remove water. If water won't go you have a bad water pump. Code FL refers to a low water flow problem ( won't fill fast enough ) or old water still in tub.
Next you need to turn off the water ot the unit and remove the water lines. Look into the water inlets on the washer to see if the dirt screens are clogged and not letting water into you unit at a fast enough pace.
Your unit has a water level sensor and should agitate when full, but I believe your machine might be "timing out" i.e. not filling as fast as your unit expects so even though it doesn't fill all the way it begins agitating because it has taken too long to fill. Good Luck!
barneyluc
Oct 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
15 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
