Question about Lexmark Wheelwriter 1000 Typewriter
Getting Tired Works beautifully, then seems to " get tired": starts printing partial letters. The next morning it works fine, then the same thing starts again.
  • carpetgary Jun 16, 2008
    Terrific! So far , so good. Applied the WD 40 on Saturday and everything is working well. Thank you.
Also, at my office we have cans of compressed air. I used that on our typewriters and it works fine. My superiors were afraid of the WD40 hurting something.
Posted on Jun 24, 2008
  • Lexmark Master
  • 3,594 Answers
Look at the ribbon. Is there a space for each letter? If so see if you can get some WD40 on the back and front of the print solenoid plunger. The solenoid is located below the ribbon just inside the l. printer side frame it dose gum up. if the ribbon isn't moving try anew ribbon and WD40 on the ribbon motor top and bottom bearings.
DickyO
Posted on Jun 12, 2008
I had a chest infection and bacteria infection for 6months it has left me so tired and and no energy what can I do to feel better
Contact your doctor. Tell him or her about your symptoms.
I hope and pray you will get better soon.
May 11, 2017 | Health & Beauty
My dishes are not getting clean anymore! It's extremely frustrating. Also, sometimes my soap doesn't even dissolve! This dishwasher isn't very old, but I am tired of it!
hi, This is a water temp. problem. The first fill s/b about 125-140 degrees. You can try running your hot water tap for several minutes. Run a load, see if there is some improvement. Next, go to your water heater, see where the setting is. On a gas move dial up a notch. On electric remove top and bottom covers and do the same thing. You also need to clean the dw off and on. Take a gallon of white distilled vinegar and pour the whole gallon into the dw after it has started and run for awhile. Then open the door and let sit overnite, starting the next morning. Hope this helps.
Jan 17, 2011 | Whirlpool Dishwashers
2000 vw golf aqy engine, starting from cold is a real nightmare its seems as if there is no fuel getting to the engine. when it dose start if it dosen't run the battery flat first. it dosen't seem to have...
It sounds like a fuel pump and/or fuel filter. Couple of reasons - if fuel filter is partially clogged fuel pump works twice as hard. Also this time of year with big temperature swings condensation (water) forms in fuel tank. If its a weak fuel pump, as pump gets old/tired it won't hold adequate pressure and drains back at night or shut down. Try the fuel filter first and run a good fuel cleaner through it prior to changing filter.
Jan 06, 2011 | 1999 Volkswagen Golf
HP Printing, copying, faxing, scanning black pages
change the ink cartridge & get your printer serviced
Jul 18, 2010 | Office Equipment & Supplies
Ribbon will not advance
mark the ribbon where it turns, where there is a pin of the typewriter passing through the ribbon,mark it with a white marker.
and type something, if it doesnt turn, you know the machine has a problem.
or try everytime pressing on the ribbon, if it works you know the ribbon is coming up, check if the correction ribbon is placed good.behind the correctable ribbon.
unaasp192
Feb 17, 2010 | Royal Office Equipment & Supplies
When printing cd's I get: paper jam and red light and reset tray
re-download the drivers for the printing program that you are using for the job, that should fix this for you. good luck!
Mar 06, 2009 | Epson Stylus Photo R220 InkJet Printer
Nascar 09
It is your disc, it has corrupted data, you need to get another copy.
Hope this Helped.
Jul 12, 2008 | Microsoft Xbox 360 Console
Canon MultiPassC555 printer
Could be a partial block - print a block of color and look for blank spaces in it, if you get them, then you should unblock the nozzle and the print head. Clean them with hot distilled water, and to be on the safe side clean the contacts as well. Good luck!
Mar 25, 2006 | Canon MultiPASS C555 InkJet Printer
Lexmark Wheelwriter 1000 Typewriter Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
