Question about Refrigerators
Center Column is getting Hot
The column/divider between the freezer and refrigerator sides is hot to the touch on the front. This is getting so hot, the magnets in the weatherstripping on the doors are getting hot, too. I am worried the whole thing is about to crash on us, fully loaded with food. We do need to change the filter, the light has been on for a couple weeks. What runs through the center colunm/divider? Had this problem, ended up replacing the compressor fan which was not moving at all despite having 120VAC running to it. Placed a fan in front of the refrigerator in the interim with the back panel off.
  • Debbie Sword Smith Sep 06, 2008
    Same problem. Mine is only 3 yrs old will try any suggestions. The computer went out on it after only a year so maybe theses Hotpoints are just junk ???
  • julieisbusy Apr 04, 2009
    Same problem.... Center wall has been getting hot for quite some time. I pointed it out to GE repairman and he said it was not that hot??
    HUGE build up of ice on freezer side - water dripping from above.
    Refrigerator not cooling - the meat compartment has never been very cold.
    Meat spoils very quickly.
    This refrigerator is 5 years old! And I've had it repaired 3 TIMES!! No wonder American Manufacturers are hurting!
    Just plain BAD - don't buy GE! I've had repairs done all the GE Monogram appliances starting at 2 and 3 years old!
    Genius:
  • 1,073 Answers
Check the condenser fan motor to see that the one that you changed is running in the right direction some run clockwise some run counter clockwise
if it is the right direction check the condenser for lint buildup
and if needed clean the coil
also check the evaperator for an ice and frost build up that can ocurr when the condenser fan goes bad
normaly the buildup of ice or frost will be on the top of the evaperator coil
just use a hair dryer to remove if needed dont pull on the ice if found or use a screwdriver or knife heat only to melt
Posted on Jun 10, 2008
2 Suggested Answers
SOURCE: Center Column is getting Hot
My side by side divider/column was getting really hot to the touch. The freezer temp was at 8 degrees and climbing. Vacuumed the front grill but not much space to clean. Pulled out the refrigerator and there was all this lint clogging the grill where the compressor and fan was. Took the grill off and clean compressor, and the whole area was dirty. Before moving it back i checked the temp. and had begun to come down and the hot spot was not hot anymore. I will mark on my calendar to make it routine to clean it Spring and Fall. After all it's been 4 yrs. since I got it and my fear was scratching the wood floor under it so i procrastinated finally the husband gave me a hand with it. Thanks for having this info available. It saved me some money$$$.
Posted on Mar 14, 2008
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
I have a KSSC48QMSO1, The center panel, that divides the freezer from the refrigerator is hot to the touch at the top end and only where the side doors close together. Also the refrigerator is not holding...
could be a problem with a dirty condenser or your condenser fan may be no good. That will cause the center panel to be hot and will prevent the refrigerator from cooling properly. Is the sides of the fridge hot to the touch as well?
Mar 18, 2011 | KitchenAid KSSC48QMS Side by Side...
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
The divider between the freezer and refrig is very hot to touch.
Normal for that strip to be warm since the cooling system is routed right behind it for heat transfer and to eliminate condensation. Will be warmer with increase in room temp, but if it is a significant change you should inspect/clean the coils behind the panel in the rear of the unit.
Jun 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Freezer and refrigerator are not cold enough.
you problem check and see if your fan condeser working best call service
Mar 22, 2009 | Kenmore 53092 / 53094 Side by Side...
Rs2630ww
You should be able to see the fan spinning if you look under the frige with a flashlight to the back or feel air flow (tissue paper helps) coming from underneath it. As for the center column, if you mean the divider area between sides, that being real hot means the compressor refrigerant is overheated. It should be warm to touch not hot. Sounds like your condensor fan is out or packed full of dust bunnies and not spinning. The compressor will overheat and "trip" the thermal overload on and off so you do need that cooling fan. All the underside of the frige needs to be clean and clear of hair, pet fuzz, etc. in order to cool properly. The fan is likely out of warranty but they are cheap and easy to replace by a homeowner.
Dec 19, 2006 | Samsung RS2630WW Side by Side Refrigerator
Rs2630ww
The light for the filter is not a problem. The thing to check is that the fan in the back is running. It should run any time the compressor is running to cool the compressor. If it is, then you need to pull the front grille or toe kick off and look under the fridge. Is there a lot of dust and dirt blocking the airflow? If so, vacuum it out. If not, pull the fridge out and check behind it. Is there a grate clogged up with dust? The reason the divider gets hot is because there is a freon line running through that part of the fridge to keep moisture from forming around the door seals. If the fridge is not cooling properly (dead fan motor or dirt blocked airflow) then the freon in this line gets very hot and all the pressures in the system rise, eventually leading to the fridge not cooling. Good Luck !
Oct 07, 2006 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
607 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
