Question about Intel Pentium 4 505J Prescott 533MHz (INTELP4505J)
My computer wont turn on it just keeps making a beeping noise it doesnt stop till i turn of the power
  • 2,794 Answers
Usually it is a loose component or a bad component. Usually a memory card or a hard drive that isn't plugged in all the way.
Check your connections.
Posted on Jun 10, 2008
I have a 2400 monitor heater-after being on awhile it starts beeping,and wont go off until i turn it off-but wheres the heat
dust build up at the heat sink fan area.Open the side panel. blow lightly with compressed air NO air? blow through a soda straw, keep it dry
Aug 13, 2014 | Computers & Internet
Load beep when i plug charger into my gateway m675
I have two of the Gateway units and both do and did beep if on and power cord inserted---normal.
Dec 01, 2012 | Gateway 17.1"lcd M675prr Notebook-laptop...
ACER Aspire 5100-U5201A Desktop makes a series a beeping sound when I use it. What could be the issue?
It may be bad ram, remove one stick of ram memory and power up the computer, repeat process making sure there is a stick of ram in the machine at all times. If the beeping stops, the one in your hand is bad.
Jul 28, 2012 | Acer Aspire Computers & Internet
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
beep noise indicates that the RAM is not detected.... TURN OFF computer....remove power the cabinet and remove the RAM.... clean it using a soft non-moist cloth...plug it back.... your computer will start... still if it is not starting, then the RAM might have gone faulty, try to check with other RAM.....
Apr 28, 2010 | Compaq CV 7500 17" CRT Monitor
My ps3 froze and now doesnt show anything on the screen and controller doesnt turn it on. nothing happens
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Computer makes beeping noise
The beeping is telling you something ... counting the beeps and matching that to the make and model on a beep decoder would answer your question.
What are you going to do about the switch controlled outlet? Id suggest you run a power strip from another hot all the time outlet. It is a death sentence to continue to shut your computer off with first warning it.
I hope this helps you
Sep 30, 2009 | Computers & Internet
My printer wont stop beeping
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
Use it will work..........
Good Luck
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Acer travelmate 4000 laptop Big problem
I guess I can assume that you have it plugged into the ac power, so you know its not a power problem. We also know its not a problem with the power switch since the light turns on. So that leaves, motherboard, cpu, and ram possible problems. Ram would unlikely cause such a hault. Even with no ram, I believe the computer would make horrible beeping noises. So if its a problem with the motherboard or cpu, its pretty much trash, unless you want to waste the money on ebay or some place for another cpu to try to swap.
Aug 23, 2007 | Acer TravelMate 2300 Notebook
Intel Pentium 4 505J Prescott 533MHz (INTELP4505J) Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
