Question about Acer Computers & Internet
My NUM LOCK doesn't work after the motherboard has been replaced....it's an acer 7720
  • sewalstad Jun 14, 2008
    It's a laptop computer...and on the acer support page...it is common in this computer and 3 other acers for the num lock keys not to work after the motherboard has been replaced.....but I still have warrenty on it, so I will be making the 5 hour trip to the nearest best buy and have them fix it....but thank you for your time, I appreciate it! It's just not the num lock it's the whole 10 key side (the numbers, the +,-,*,/,enter, pageup...etc,etc...). But thank you for trying....
    Sergeant:
  • 243 Answers
Have you tried a different keyboard? to ensure that it is infact not just the keyboard having a broken key? as the num lock feature has little to nothing as i would see it to do with *********** board? its a standard keyboard thing.. i guess there could be a bios setting? but i would say try that keyboard on a different computer then try another keyboard on your computer? and then let me know - thanks nate
Posted on Jun 13, 2008
  • Nathan Ayers
    Nathan Ayers Jun 13, 2008
    it some how blocked out "the motherboard". thats a first.
  • Nathan Ayers
    Nathan Ayers Jun 14, 2008
    well then why did you put it under pc desktops and you give me a thanks for trying. should have a thanks for wasting my time. next time itd be better to identify everything that you stated on your second comment.
Reset BIOS? how to
With both PC and LAPTOP Motherboards,Pc Motherboards are easier to Wipe Passwords than laptops because of ease of getting to the Jumper on the motherboard normally by the battery on the motherboard.I would suggest looking online for the motherboard manual which should show you where the bios reset jumper is.Laptops are just the same but a lot harder sometimes to find this jumper. Hope this helps
Aug 26, 2014 | Acer Aspire 7720 Notebook PC
NUMERIC KEYPAD NOT SUPPORTED
Might give this a try-right click on your Computer icon-click on Properties-then click on Device Manager. The keyboard is listed there. If it has a yellow exclamation point, or a yellow question mark, then there is a problem. Click on the arrow in front of Keyboards, then right click on the drop down named keyboard. There you can click on update drivers. That should solve the problem.
May 07, 2014 | Acer Aspire 7720 Notebook
Acer Aspire 7720-6155 wont boot
put cd in dvd writer then open the laptop and press f8 and after that if lap asked for esc/ or for enter press esc then it will work .
Sep 12, 2013 | Acer ASPIRE 7720-6155 LAPTOP LCD SCREEN...
Num lock
If you use the number pad frequently during your daily computer usage, you may want to have the "Num Lock" key enabled when the computer starts up.
You can enable Num Lock automatically in two different ways: one involves modifying a value in the registry and the other requires you to create a small script in Notepad.
Activate Num Lock Through the Registry
Enter the registry and navigate to "HKEY_CURRENT_USER\Control Panel\Keyboard\." Double-click on the value labeled "IntitialKeyboardIndicators," which has a value of 0,1 or 2.
Change the value to "2" to turn Num Lock on after logon, "0" to turn Num Lock off after logon and "1" to disable Num Lock.
Create a Num Lock Script
Configure a script that runs to automatically change the Num Lock state.
Depending on where you place the script, you can activate the script for a single user or all users on the computer. Open Notepad and paste the following code
"set WshShell = CreateObject("WScript.Shell")
WshShell.SendKeys "{NUMLOCK}"
Save the file as "numlock.vbs," including the quotes to change the notepad file to a script.
Paste the file in the directory "Documents and Settings\All Users\Start Menu\Programs\Startup" to enable Num Lock for all users by default.
For a single user, copy it to their startup folder instead of All Users.
Enter the BIOS
Enter your computer's BIOS before Windows boots up to change the integrated Num Lock settings.
Depending on your motherboard manufacturer, different key combinations allow you to access the BIOS.
Common keys include "F1," "F2," "Del," "ESC" or "F10."
Consult your computer's documentation for specifics.
Navigate through the basic or advanced options until you find a section dedicated to enable or disable Num Lock on boot.
Enable in Linux
Linux is an alternate operating system.
While the BIOS method may work for Linux, you can also change the process through the options if using KDE Linux.
Navigate to "Control Panel" and click "Peripherals." Select "Keyboard" and select the option "Turn on" under the heading labeled "NumLock on KDE Startup."
How to Set the NUM LOCK State at Logon in Windows XP
http://support.microsoft.com/kb/314879
How do I enable the NUM LOCK key for the logon screen
http://support.microsoft.com/kb/154529
May 15, 2013 | Compaq Computers & Internet
Unlock number lock
On a laptop, the "Num Lock" key has a function slightly different than the one it performs on full-d desktop keyboards. Activating "Num Lock" on a laptop usually transforms a set of central keys, including many letters, into number keys, allowing typists used to entering numbers on a keypad to type efficiently. While on desktop keyboards "Num Lock" usually has a dedicated key, on laptops it often shares a key with another function on MacBooks, for example, it shares the "F6" key and you must hold down the "Shift" or "Fn" key to activate it.
Look for the "Num Lock" key on your laptop's keyboard. This is usually near the top of the keyboard. If the key says nothing on it except "Num Lock" if that's the only function the key performs you can just press it to activate the lock; a light will probably go on somewhere to indicate that "Num Lock" is on. If the key has multiple functions, you'll have to hold down a different key while pressing it. Hold down "Shift" and press "Num Lock" if the writing saying "Num Lock" appears above some other writing on the key, the way various symbols appear above the numbers on the keyboard's number row. Hold down "Fn" and press "Num Lock" if the writing saying "Num Lock" appears in a different color often light blue that's shared by the "Fn" key.
Feb 28, 2013 | Acer Aspire Computers & Internet
What's your problem?acer aspire 7720 numeric side doesn't work after change MB
Is your keyboard a PS/2 or a USB one ? if its a PS/2 (the cylindric connector) find a PS/2 to USB converter and plug it into a USB port (the flat rectangle connector)
Feb 02, 2012 | Acer Aspire 7720 Notebook
The Numeric keypad on my Acer Aspire 7720 doesn't work. When I press Num Lock key the indicator light doesn't come on. The main keyboard works fine. I am using Vista.
try to access command prompt outside of windows using the operating system disc. (by booting to cd and go to repair your computer options then select command prompt) if the keyboard works fine on command prompt, there's no issue with the hardware. but if it still doesnt work, you will need to replace the keyboard.
Dec 03, 2009 | Acer Aspire 7720 Notebook
I have an acer laptop 7720. my screen stoped
sent it back ..tell them all the issue that you got after you received it....but the files in your hard drive..i dunno if they will help you..its SOP to tell to the customer to back up your hard drive b4 you sent the computer...you also have choice to keep your hard drive before you send your computer for repair...software or files are not cover for warranty
Mar 16, 2009 | Acer Aspire 7720 Notebook
Aspire 7720-6569 laptop automatically shutoff and won't turn on.
hi,
Please try following DIY
1.Please remove the battery and then press the power button for a minute without connecting the adaptor then refix the battery and check whether it is working.
2.Check after removing the battery with adaptor only.
3.If then also it is not working check whether the num lock is responding if yes then this is a RAM refixing or changing issue otherwise a motherboard issue if the adaptor is working fine.
Feb 21, 2009 | Acer Aspire 7720-6569 Notebook
Computers & Internet Logo
942 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
