Question about Kenmore 22422 Top Load Washer
Kenmore automatic washer direct drive: slippy clutch
The clutch is to slow and i can stop it easely.
I opened the bottom, and the clutch pads are used, but there was oily and black dirt in.
I pull out , motor, gearcase, there is ok
I want to pull out the drive tube but dont again the screw is stick. i just make a spanner tool (i'm machinist) i try tonight.
I suppose oil from the base tube by oil seal.
WHY ?
If not, what do you think ?
    Genius:
  • 1,028 Answers
If oil on clutch ckd top of gearcase under clutch drum top gearcase seal may be leaking
Posted on Jun 11, 2008
  • olive02 May 05, 2011
    you can buy the parts that you need in sears parts store. just call them or bring the sample to the parts depot.
    Kenmore Elite Dryer
Kenmore Direct Drive Washer Slow Spin 11023812100
there is a switch on the motor check the wiring make sure it is working
Apr 05, 2014 | Kenmore Washing Machines
My Kenmore Elite washer spins to slow cauisng the
If this is occurring mostly on heavier loads your clutch may be slipping. If you take a flathead screwdriver and push down the lid switch so the washer will spin with the lid up, grab the inside of the drum. If you can easily stop the drum its most likely a bad clutch. If you tip the washer back and see oil underneath then its probably your transmission leaking oil onto the the clutch causing it to slip (in which case you need transmission and clutch assy). If you see oil I would probably not bother calling a tech it would be a pretty expensive repair.
IF the problem is with the clutch only it may be worth repairing but to replace the clutch you will have to remove the pump, motor, transmission, and the clutch mounts on top. The other less common possibility could be a bad drive block under the inner tub. hope this helps. _MJ_
Jan 28, 2010 | Kenmore 15864/15862 Top Load Washer
Washing mashine tub pounds when spinning on kenmore series 70
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the component section on the base of the washer.
There are springs and friction pads designed to keep the inner tub from moving too much when agitating and especially spinning.
One or more of the springs may have come loose or the friction pads may have worn.
Following is the Whirlpool / Kenmore installation and service manual for top load direct drive washers with a troubleshooting section.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to remove the cabinet in order to gain access to the springs and pads.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the springs and pads are fine, I'd consider looking into the "agitator cam" in the transmission.
If the cam doesn't lift the agitator gear high enough during the spin cycle, (as we had) you would get a major vibration.
See the section in the Whirlpool manual on how the transmission works and the agitator cam.
We had to replace ours and the vibration stopped.
Only if you need to, look at the following.
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Oct 19, 2009 | Kenmore 22422 Top Load Washer
Hello experts! Kenmore is slow to spin
you may need to replace the direct drive coupling. this part consists of 3 pieces, an inner rubber piece sandwiched between to nylon pieces. it is situated on the shaft of the motor. it is a wearable part and also an inexpensive part to replace. if you are handy you can do this yourself. hope this is a help to you.
Oct 14, 2009 | Kenmore 44102 Front Load Washer
I have a Kenmore 80 series washing machine and the spin cylcle isn't working. There is a loud grinding noise during the spin cycle and the tub doesn't spin.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This also assumes that:
1. The machine will agitate and go through the rest of the cycles.
2. It will pump out the water.
3. Since it tries to spin, the Lid Switch is OK.
The problem points to the clutch and / or transmission
See the following for how to pull the clutch on Kenmore top load direct drive washers.
If the clutch springs and pads seem OK, the problem points to the main spin gear inside of the transmission. If the clutch springs and/or pads are damaged, there is a rebuild kit for them.
Following is the Whirlpool / Kenmore installation and maintenance PDF on how their top load, direct drive, neutral drain washers work.
Here is another PDF of the Whirlpool parts list for their commercial washers, consumer models are basically the same.
If you look at the operation PDF you'll see how the transmission works when going into the spin cycle. If the "Neutral Drain" cams are intact, they drive the main spin gear which drives the spin gear connected to the clutch.
If the main spin gear is broken (It's a metal plate surrounded by plastic gears) you would hear a major grinding noise and the washer wouldn't spin.
Opening the transmission is not difficult but is a messy job. It holds about 14Oz. of oil.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the main spin gear or neutral drain assembly cams are damaged, they aren't too difficult to replace.
The Whirlpool Parts PDF has part numbers for both.
The Neutral drain assembly costs about $15 which is a lot less than $170 for a new transmission.
The Main spin gear is quite a bit more but still less than a transmission.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Model 925 75 110 washing machine makes loud noises when the spinning cycle ends (as it stops spinning). Any ideas? Ease of repair ?
There is also an excellent PDF document from Whirlpool describing how Direct Drive washers work.
We has the same basic problem with a Kenmore direct drive washer. At the end of the spin cycle we heard a loud noise as the brake stopped the drum from spinning.
Sometimes, what can happen is that the brake will grab the brake drum, like a brake on a car suddenly locking a wheel.
The brake is supposed to slow down and stop the drum without locking.
We were able to spray a small amount of silicone spray inside the brake drum, which allowed the shoes to more gently grab the drum.
See GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
Remove the cabinet and look at the drum directly above the silver colored clutch assembly.
Using an spray can of silicone spray, and a directional tube, spray a very small amount into the brake drum.
Sep 25, 2009 | Kenmore 22422 Top Load Washer
Washing machine squeals after replacing clutch
Yes, you could have gotten some oil or lube on the clutch assy. If this doesn't clear up within a few cycles, then there is more wrong but I feel that this will clear up. What is happening is as the clutch engages, the oil/lube on the clutch pads makes this slip a bit and then it catches as it goes on. I hate to have you do all that again to clean the pads but if it doesn't clear up in a number of cycles, then you may have to. As I said, I believe this will clear up in time :)
Hope this is helpful to you
Joe
Aug 29, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 70 series adgitates but wont spin the clothes out
this is joyce
The belt is usually found on the bottom or the back, but if you want the sceamatic on your machine go to kenmore.com and put in your model# and download your manuel and find out what you are looking for.
thanks
joyce
Feb 11, 2009 | Kenmore 24032\24036 Top Load Washer
Washer machine makes noise each time the tub stops spinning
theirs a brake that slows the tub down .Ive fixed 2 thousand off these washers and its not a normal problem.as a repair man i would remove traine,inspect clutch,brake and spanner nut and drive block area
Dec 31, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Dec 19, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
326 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
