Question about Janome Sewing Machines
Top tread bird nesting.
I own a Janome 300 Embroidery machine and used it for almost 5 years, two months ago, the top tread started bird nesting, so I took my machine in to the same store I purchased it from for repair. I had my machine back for two months and the same thing happed again, so back in it went. Now the same thing append again. It's getting to expensive for me to keep taking it back in to get the top tension fixed. I am using the correct backing for the different types of material I use. I have to drive a long distance to get my machine fixed and with what gas prices are today I just can not afford to keep taking in my machine.
Please I need help. Can you tell me how to do it myself.
  • Coribug Jun 11, 2008
    When the design is sewing on the garment, the top thread is loopy and bulky, also there is no bobbin showing on the back of the garment, just the top thread. The bobbin is not loose, no lint has accumulated under the bobbin case I checked. Hope you can help.
    Problem Solver:
  • 26 Answers
When you say top thread nesting, I supose you mean that the thread is messed up at the top of the needle plate.
If so,
1st, either your bobbin thread is completely loose, or the bobbin thread is not held under the bobbin case spring,
or lint has been accumulated under the bobbin case spring.
2nd, the top thread is very tight,
or both.
Posted on Jun 11, 2008
  • Antonis Lasettas
    Antonis Lasettas Jun 11, 2008
    Use a different color of thread for bobbin, and tell me the result, please.
Janome 6600 top tension too loose... a big wad of thread underneath. I've re threaded, tried a new bobbin, cleaned the machine.
Sounds like thread nesting (or bird nesting).
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct,.
Set the upper thread tension to the midway point and then tweak it for your machine.
Jul 29, 2017 | Janome Sewing Machines
Janome one step Despite altering the tension dial the top thread is looping on underside of material and when pressing the reverse button material puckers.I tried adjusting the tension dial from 0-9
Usually, this occurs because the top thread is not fully seated in the tension disk.
Reset your top tension to the midway point and then tweak it.
What causes Bird Nests Superior Threads
Birds nest under the fabric big loops of thread top side looks good...
Jun 07, 2017 | Janome Sewing Machines
I have mc9900 janome when trying to embroidery on t-shirt material threads bunch up in back and I end up with holes in shirt
Are you using a fabric stabilizer to prevent the t-shirt fabric from stretching?
Also, be sure to Always Raise the presser foot when threading the top thread. Knots could be bird nests.
May 08, 2017 | Janome Sewing Machines
HOW DO I OIL A VIKING DESIGNER SE EMBROIDERY MACHINE, TRYING TO FIX THE PROBLEM OF BIRD NESTING.
bird nesting is from needle thread tension being too loose
increase the tension up
May 02, 2017 | Sewing Machines
Hi I am having problem with my sewing machine. Thread gets all tangled up on the bottom of the fabric... My husband is very smart about machine and needs just suggestions from you.
That is called bird nesting or thread nesting and usually results from: mis-threading, thread not seated fully in the upper tension disk, or upper tension too loose. (Mis-threading may not be a user error--sometimes the thread will "jump" out of thread guide or the take-up lever.)
Remove the thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the upper tension at the midway point between high & low number and retest your machine. The upper tension will probably need some tweaking for your particular machine, but the mid-point is a good place to start.
Tutorials Urban Threads Unique and Awesome Embroidery Designs
Jan 12, 2017 | Sewing Machines
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
My bobbin isn't sewing correctly
If the bobbin stitches look out of whack, your machine is probably threaded incorrectly. rethread with the presser foot up and see if this fixes the problem.
May 20, 2016 | Singer Inspiration 4206
I have used my Embroidery machine for a couple of years and have not near mastered it, My thread is too loose, then at the same time the bobbin thread is pulled through to the top. Yes the bird nest is...
When you're embroidering, ALWAYS have the tension set on "E." Unfortunately with a Singer, you will always have bobbin thread pulling thru to the top-I found this out from a technician a few years ago who also serviced Vikings and Husqvarna's. He went through a lot to show and explain it to me, but suffice it to say that with a Singer you need to use the same thread in the bobbin as on top when you're embroidering-it's simply a flaw with their machines.
The bird's nest could be a number of problems, but first we need to be sure you're setting your tension set on "E". If you are, leave me a comment back and we'll go through some specific steps to take about the bobbin. Otherwise, correct you're tension setting and see if that corrects the bird's nest problem. If not, again, leave me another comment back and leave me any details you can as to the type of material your embroidering on, the thread you're using, etc. It may seem like a pain, but you'd be surprised how fussy the littlest thing can be. I check in daily, so I'll get back to you within 24 hours. I've used my CE100 for 4 years and have mastered it quite well, so I feel confident that I'll be able to help you.
May 29, 2011 | Singer CE-100 Futura Computerized Sewing...
Janome 4400 bought new bobbin holder but still have lots of issues with thread looping while sewing. The repair person says I pull the thread forward after cutting it and undo the proper bobbin threading....
looping the material ( bird nesting) is an indication of incorrect needle thread tension before threading the needle pull the thread and there should be resistance to the pulling
Nov 15, 2017 | Janome MC 4400 Computerized Sewing Machine
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
Sewing Machines Logo
392 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
