Screen problem i have a blank white screen on my laptop, have had to link my laptop through a monitor
  • chetchilds Nov 26, 2008
    Inspiron 1525 boots fine and about five minutes it goes white and doesn't come back. If you hit the HOME keep the dialog box for Dell Media comes up and the task bar apprears. Close the dialog and everything goes white again. Restart the machine and it comes up and repeats above.
    I had just install AVG-8.0 when this started. Any connection?
  • Anonymous Dec 12, 2008
    I get same problem with an HP Pavilion desktop and Sceptre monitor. Is problem likely hardware?
  • 191 Answers
If the display on the external monitor is fine in that case it is an issue with the LCD as you get a video output on external monitor
you have to get the LCD either repaired or replaced.
Posted on Jun 10, 2008
I have the same problem. I have to connect my laptop to an external and reinstall the ATI drivers, shutdown, disconnect the power cable, pull out the battery, put the battery back in and reboot.
It's not a hardware problem, it's a software problem. Do not replace your screen. It will cost more than your laptop is worth.
Now if somebody has a real solution, that would be great. Thanks.
Posted on Aug 03, 2008
I have the same problem and same computer IBM t43. How do I link to an external monitor. Can I just use an old lap top and a cable?
Posted on Jun 17, 2008
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computers & Internet
How do I fix a blank white screen
Hello, another test is to connect a monitor to the VGA out or (other video option) and if the results is still a blank white screen then a repair is definitely needed.
Jun 19, 2014 | HP Pavilion dv6000z Notebook
Computer screen is white and blank..the last thing i did was run a disk defrag and now its completely white...i dont know how to reset the monitor and i hook it up to my laptop to a double monitor options...
Not sure what you mean by resetting the monitor but pulling the power should get it back so you can see the Onscreen menu. If you can get inot the menu there is usually a reset or factory reset option.
As for dual screen w/laptop. The hardest part is telling the laptop to use the extra monitor. On my laptop the Function Key and F8 cycle the external monitor. You also need to tell windows if the new monitor sits to the left or the right of the laptop so the mouse works correctly.
Mar 08, 2014 | eMachines E17T4W 17" Monitor
Blank screen/white screen
Plug in a monitor to the VGA connector on the side. The white screen usually indicates a failed inverter. By using an external monitor you will cut down the likely causes.
Apr 30, 2013 | HP Compaq for Presario V3000 Motherboard
Laptop screen blank all white
Either your LCD Video Cable is not plugged in snuggly or the monitor is slowly going bad. The fact that you can see the images on an external monitors says your Video Graphics Card is working fine. You'll need to disassemble the laptop to get to the cables. Get a quote from your local computer shops, then try the guys at: http://www.generalsystemsconsulting.com Most times they will fix it and ship it back by Fedex or UPS cheaper than any quote you obtained including the shipping.
Mar 15, 2012 | Compaq Presario CQ56-115DX Laptop
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Montor shows a blank white screen and is unresponsive
Please try to connect the monitor to another PC, if it continues to happen, then probably an internal electronic part/s of your monitor is cold soldered / defective which failed to send signal to other hardware parts of your monitor thus you only see white display. I suggest to bring the unit to an authorized service center fix / replace the cold soldered / defective part/s. regards
May 28, 2009 | Dell Computers & Internet
Purchased a Acer Aspire 2930z. i get a blank white screen.
Connect an external monitor to your laptop and power the laptop up, if you get a normal image on the external monitor then you have a faulty LCD screen and may be replaced. If you still get a white screen then you most likely have a faulty video card.
The video card is part of the motherboard and usually cannot be repaired, the motherboard is normally replaced but it may not be cost effective to replace. If the laptop is a several years old then it is time to get a new one.
Mar 08, 2009 | Acer Aspire 3610 Notebook
Computers & Internet Logo
1,314 people viewed this question
David Payne
David Payne
