Question about Goldstar DH304 Dehumidifier
Runs 5 min then quits
The dehumidifier runs about 5 minutes then shuts down. If I manually dial back to the off position then dial it to max, it will run another 5 minutes before quitting. I've cleaned the filter and the coils. Could it be the "full" switch?
  • 4 more comments
  • zoebe111 Jun 10, 2008
    goldstar 30 pint runs for 2 minutes, then quits. If I take the water container out and replace, it starts sometimes. mostly doesn't even start now. fairly new unit. help
  • Anonymous Aug 25, 2008
    No solution. Removing tub and re-inserting allows it to start up, then a minute later it quits... regardless of dial settings.
    Hope there is an easy fix.
  • cubs759 Feb 21, 2009
    Thanks to the person who wrote "Yup, had the same problem. This is due to a bad humidity control switch (the white dial you turn on the front). It needs to be disconnected." You just saved me some much needed cash.
    Good deal! -Ken
  • Anonymous Mar 23, 2009
    same problem unit is 1 years old .rune for a minute then shuts off.Remove water bucket and then runs again for only 1 min.
    I had the same problem! I cut the two white wires and now it works great. Thanks everyone!
  • 67gto Apr 30, 2009
    I took the cover completely off mine so I could disconnect the white plug next to the blue plug in the electrical box. I didn't want to clip any wires in case i could get the correct part which seems to be a humidity sensor. I works great again. Just doesn't shut off until it's full which is no big deal. Easy temporary or permanent fix!!
Whomever suggested clipping the white wires to the dial was right on and saved me from spending another 170 bucks Thank you!!!
Posted on Sep 10, 2008
I had the same problem with the unit not staying on. I also followed this suggestion (cutting the white wires leading to the humidity control knob) and it now runs continuously. I have no mechanical ability but was able to follow the instructions without a problem. My only concern now is having the system running when there is no humidity. Will it be safe? I unplug it when it isn't humid to be on the safe side. Eventually I'll have to buy a new humidifier, but this will work for now (it's only 2 years old). Thank you for help!
Posted on Sep 01, 2008
Had the same problem and I too cut the white wires leading to the himidity level switch. The unit came on immediately and has worked ever since (with same limitations as mentioned in the first solution post).
Posted on Aug 24, 2008
Yup, had the same problem. This is due to a bad humidity control switch (the white dial you turn on the front). It needs to be disconnected. If you are a do it yourself-er there are 2 ways to do so. Disconnect the white plug next to the blue plug in the electric box inside. (a lot of screws this way). Or (the easy way) remove the water tray from the front, unscrew the 2 black screws hidden by it, unseat the tabs from the front panel (one on each side, and two on top) then snip the 2 white wires that lead to the dial. (not the shut off light). You can't shut it off with the dial after this, but it will shut off when the water tank is full or when you pull it out. I am not a technician, I just like to fix things that cost me money.
Posted on Jul 30, 2008
Same problem?
Posted on Jul 23, 2008
Why will my Sante fe works but will not shut off.
initial thought would be faulty switch, need to check it
Aug 13, 2014 | Santa Fe Max Dry Dual XT Dehumidifier
I have a model KU 34313 Kul dehumidifier and i cannot get it to stay running , I plug it in and it runs for 2 minutes and then shuts off? cannot find manual
We too have the same problem but it is with the KU34513 Model it may last a whole 15 minutes max then shots off with ERR message.
We bought it after last recall.Now there is another recall. Is this a safe model? Fix or replace?
Jun 28, 2014 | KUL 50 Pint Dehumidifier"
I have a goldstar dehumidifier that runs for a couple min. then turns off. I unplugged the rheostat wires from the mother board and it runs just fine. Does that mean if I replace the rheostat switch the...
Runs for a few minutes then shuts off, easy fix. First, remove water catcher and slide filter out and clean it. Then find the two screws that hold on the front panel remove front panel. Make sure the unit is un-plugged. The humidity control dial has two wires connected to it. clip the inner wire. This will keep the unit on full. You could replace the humidity control dial, but why bother?
Dec 12, 2011 | Goldstar DH304 Dehumidifier
Recently bought a Frigidaire Dehumidifier four days ago. Ran it for 3 days on the co setting as the manual instructed. When I set the humidity level, after about 5 minutes it shuts down...does not come...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jan 21, 2011 | Frigidaire FDL25P1 Dehumidifier
Dehumidifier runs for approx. 15 min works fine then shuts off and doesn't come back on.
run it without the filter with a 1 part vinegar 4 parts water. then try it with a clean or new filter. You may need to run it a few (5-6) times before it stops shutting off by its self.
Aug 22, 2010 | Kenmore 54351 Dehumidifier
Zenith ZD30 dehumidifier - 1 1/2 years old stopped working had a half bucket oc colledted water in bucket when it stopped. I checked the fuse on the circuit board and have continuity.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Jun 16, 2010 | Dehumidifiers
It starts with control set to max and it runs a couple of minutes and it stops so i turn the control to low and back to max it starts again and stops the same way the humidity is at 60+ so it should stay...
one of 3 possible problems,the control is faulty,you can bypass this with a jumper wire and see if it stays running, the condenser coil is dirty and is not cooling the compressor correctly and the condenser and evaporator coils need to be cleaned,i would do this first before bypassing the control,then possibly its low on refrigerant and the low pressure switch is shutting it down or the switch itself is faulty,please rate this if it helped you,thank you
May 30, 2010 | Goldstar DH304 Dehumidifier
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
Dehumidifier model M7DH65b 2A
Its too old where you are running the appliance - lift it up in the air or raise the heat in the room. This is *not* a low-temp dehumidifier.
Jun 09, 2008 | Maytag M7DH65B2A Dehumidifier
Goldstar DH304 Dehumidifier Logo
527 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
