Question about Lexmark Office Equipment & Supplies
My Lexmark Series 3100 (model 4477-001) works excellently However, Yesterday I lifted the cover to inspect and then closed as usual..Now I get a message when I try to print that the cover is open. I have tried to fix this about 10 time but with no success Please help>
  • 2 more comments
  • v4d6x4mh Jun 10, 2008
    I would have guessed that myself, but it is of no help unless you identify "sensor" and "switch" Since I do not have a design plan this is of no help
    That is no for warranty. A service manual might help
  • v4d6x4mh Jun 11, 2008
    I tried shaking and examined the three holes I found in the cover. No success.
    I still can't find a sensor. However your suggestions are at lesst operative and not the nonsense given by EKSE (which I certainly do not consider expert advice)
    President:
  • 2,712 Answers
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
1. You can first try a hard reset and see if that helps..Unplug printer from AC power source, and disconnect from PC. Wait about 10 minutes, and reconnect to AC source and PC. Now turn on the power button on the printer and see if that helps.
2. Try blowing the insides with a can of compressed air to clear out any dirt/debris from inside.
If that doesn't work, then please contact Lexmark Technical Support for additional assistance here:
http://support.lexmark.com/cgi-perl/contact.cgi?ccs=229:1:0:23:0:0
NOTE: When calling for service, you will need to know your printer model type and serial number.
Please call from near the printer in case the technician asks you to perform a task involving the printer.
You can get a service manual by contacting 1-877-577-2787.
Hope that helps!
Posted on Jun 11, 2008
    Master:
  • 638 Answers
ITS A SENSOR PROMBLEM MY DEAR FRIEND.JUST CHECK OUT IS THERE ANYTHING STOPPING THE COVER TO DETECT THE SENSOR.ALSO TRY TO CLEAN THE SENSOR TO CLEAR OFF ANY OBJECT THAT IS STUCK IN.
Posted on Jun 10, 2008
  • 4 more comments
  • hemant somaiya
    hemant somaiya Jun 10, 2008
    ALSO TRY TO SHAKE A PRINTER BIT HARD SO THAT IF THE SENSOR IS STUCK SOMWHERE CAN CATCH ITS NORMAL POSITION BECAUSE OF A ****.
  • hemant somaiya
    RATE THIS SOLUTION AS FIXYA IF U FIND IT HELPFUL
    FEEL FREE FOR ANY FURTHER ASSISTANCE.WE ARE ALWAYS THERE TO HELP U.THANKS AND WISH U SUCCESS.
  • hemant somaiya
    SENSOR IS VERY EASY TO FIND AS IT ALWAYS HAS A OPEN OUTLET OVER IT WHICH IS COVERED WEN U CLOSE OFF THE DOOR.JUST CHECK OUT THE CORNERS WERE UR PRINTER TOUCHES IF U DOOR WHILE CLOSING.
  • hemant somaiya
    hemant somaiya Jun 11, 2008
    do u want any tecnician to repair in ur area.just let me know ur location n zip code.
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    any updates let me know.
  • hemant somaiya
    hemant somaiya Jun 17, 2008
    any more assistance.
  • Lexmark Master
  • 13,433 Answers
A sensor or a switch is probably stuck and it thinks that the cover is still open.
how to fix this? I suppose you would have to take it apart - warranty?
  • 4 more comments
  • Ekse Jun 10, 2008
    I suppose thats No for warranty. lets see if we can find a service manual.
  • Ekse Jun 10, 2008
    Can't find a Service manual for your model, I suggest you contact lexmark - they also have tech support on the site. Il check there if they got instructions on this.
  • Ekse Jun 10, 2008
  • Ekse Jun 10, 2008
    I ment call there / ask there for a service manual for your product I didn't find one available publicly.
  • Ekse Jun 11, 2008
    in that case please request more assistance from other experts. your problem gets posted publicly and other experts can asnwer to your problem.
  • Ekse Jun 11, 2008
    I've also sent your problem to another expert expect him to respond within 24hours.
Descargar instalador lexmark 3100 series
If you have Windows XP o server o 2000 descargarlo de este link support lexmark com if you have 7 is not supported by Windows 7 even you can make the scaner work with this trial software http://www.hamrick.com/
Other options of download just in case
Lexmark 3100 Series 1 0 3 0 Lexmark 3100 Series
May 14, 2014 | Computers & Internet
Is a Lexmark 3100 series printer mac compatable?
Yes ,Lexmark 3100 series printer is mac compatible .
For driver for mac you can download from the link below .
MAC driver
Hope this helps .
Mar 16, 2010 | Lexmark P3150 All-In-One InkJet Printer
INSTALLED NEW INK IN X3470 AND SAYS COVER OPEN WHEN IT IS CLOSED
Look at either side of the flip-up cover. While I am not familiar with Lexmark printers, I have seen this problem in the HP 6800 & 6900 series. There should be on one side (my guess would be closest to the 'rest' position of the ink carriage) some sort of switch to detect cover position. In the HP printers, the switch is 'down' when the cover is open; so, if the little lever that would lift the switch to the 'up/closed' position if broken, the switch stays in the down position and the printer thinks the cover is open. Look for something along these lines.
Feb 16, 2010 | Lexmark C533DN InkJet Printer
1997 Hyundai Excel will not start- started and ran well yesterday
hi--have the timing belt checked-- just remove the cover on the left side of the motor or #1 end and turn it over to inspect the belt--cheers
May 04, 2009 | 1994 Hyundai Excel
LEXMARK 3100 SERIES NO LONGER APPEARS UNDER PROGRAMS??
HI!
Happy new year to you too.
Please select the printer model number download the driver and install it on your computer please follow the onscreen instructions from the link below.
http://support.lexmark.com/cgi-perl/selections.cgi?ccs=229:1:0:-1:0:0&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&lxkprod=LEXMARK+3100+SERIES&req=:::-1::
If you need further help please get back to me
Regards
Mohammed.
Dec 29, 2007 | Computers & Internet
59 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
