Question about Edirol UA-25 External Sound System
My Edirol UA-25 suddenly is not working with Nuendo
I have aN Edirol UA25 which has just suddenly stopped working with Nuendo 3.2. The computer says the edirol is there and I can run sound through it. I tried uninstalilng the software, reinstalling and restarting the computer, that didn't help. It was working although glitchy yesterday. I have two computes with Nuendo 3 and it is the same for both of them. Nuendo first said the device is not connected and not it doesn't recognize it all. Though it still appears in advanced VST and I can get the output to work through the edirol but I can't record which is the most important thing. Is this an updated driver problem? If so, I'm stumped I haven't found a driver compatible that can solve this, I tried!
My computer is using Vista
I need to record my show and I'm tearing my hair out! Please help
  • 5 more comments
  • mrleondee Sep 24, 2008
    Exactley the same problem. Through Vista too
  • Anonymous Oct 30, 2008
    it says that it will not work with an inteled-based mac.... it worked before then just suddenly stoped
  • LRAnisa Mar 13, 2009
    I Just got nuendo 3 and my interface (edirol ua-25) its not showing up when i go to device settings.
    im not sure if its the edirol is uncompatible with nuendo or another reason.
    Please answer asap thanks .
  • kjetinas Mar 15, 2009
    Input suddenly not woring for me as well. Also, running ACID it says that the UA-25 doesn't support the current sample rate or bit depth. It always worked before, so I really don't get why it suddenly doesn't.
  • Ian E Apr 23, 2013
    I have the same problem, it suddenly stopped working, i have vista, it lights up and it shows, im sure my microphone is working.. it just won't detect anything, in any program from the edirol :(
    I have exactly the same problem ^^ have you managed to fix yours? I have Windows Vista still ;( the edirol is lighting up and is detected by all programs, but no instruments are working or being monitored by acid pro, audacity or skype or any program :(
  • Anonymous Mar 18, 2014
    Hi there, I have been recording with M-audio with Nuendo for a while and have a never before encounter problem. When I open my tracks up, i set-up all the device connections as usual and then when I play the track, icant hear anything in my headphones. I can see the levels moving, but no sound is possible. If i switch the driver I can hear playback through my computer speakers only but not through the M-audio. have no idea what the problem is. Can you help? Thanks - Trisha
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Posted on Sep 08, 2008
  • tobycole1974 Dec 12, 2010
    i found that going into device manager and disabling the onboard sound drivers that my ua-25 worked straight away as the default, hope this helps guys
  • NicolaCairnX Mar 10, 2011
    that number is unobtainable now
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Ua25
Hello. Sometimes the USB voltage is not enougth. Try connect the usb cable into another USB port, preferring the rear panel connectors. The UA25 drivers must be installed previously.
Feb 07, 2013 | Edirol UA-25 External Sound System
Crackle/static during audio playback.
hi,
download Realtek high definition sound manager software, this will filter your noise and give u a good result.. all the best..
thanks
ehsanullah. md_ehsan_1@yahoo.co.in
Jun 16, 2009 | Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Edirol ua25 jack speaker output
Your are using powered speakers right? Or going into an amp and then the speakers, as the UA-25 does not have enough power to drive passive speakers.
Call Roland customer service and have them walk you through the device setup to make sure you've got everything right.
EB
Jun 06, 2008 | Edirol UA-25 External Sound System
Edirol ua-25 not detecting midi but audio works fine
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Feb 27, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Edirool ua25
What version of windows our you running, you might have to go to control panel and make sure it is the default audio out
Jan 21, 2008 | Edirol UA-25 External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
1,071 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
