Fuel injected? Could be the fuel line on the pressure side of the pump, (in the tank) not holding pressure. could also be a loose fuel fitting from the tank to the carb. Make sure the line on the outside of the tank is secure, then check to see if you can hear fuel moving in the tank. If you can hear the fuel moving, (with the ignition switch in the on position), it is probably a split fuel line inside the tank.
