Question about HP Computers & Internet
Printed an alingment test and a copy keeps on printing before I print off any work that I am trying to print
  • 47 Answers
First, try shutting down your computer and restarting. This should clear the print queue, which might have become "confused". You can also turn off the printer to eliminate any stray print job that might be remaining in it's memory.
Posted on Jun 10, 2008
I put in a new cartridge (56) and now my alingment
after replacing the cairtage printer needs alignment it gives a test page when we put it face down on scannes it starts the alignment...
on alignment process it doesn;t found the colour bands so it shows the alignment failure..........
pls install the new colour cairtge the it will give u the printout
Jul 08, 2010 | HP PSC 2210 All-In-One InkJet Printer
My sato cl408e is printing but 1/4 of the print on the inside of the label not readable. very dull and missing print. The other 3/4 of the print is perfect. Could this be a dirty print head or the...
It could be a print ehad problem, or an out of alignment condition between the platen and the head.
YOu can use a test mode to print a factory test print, that will put the print across the label. Settings and a barcode for alignment will be pirnted.
If you are using less than full width stock, only print 5 or less labels as the head will try to print across the full width, and if no label present, may harm printhead.
there are adjustments on the outside(right) of the platen support bearing that you can loosen the screw, and cam adjustment, to level the head across the platen.
Mar 02, 2010 | SATO CL408e Label Printer
Is there a way to keep track of copies printed?
you could print a self test page from the printer, you could find the info of no copies printed in that page.
steps to print self test page from the printer are
presss seetup button on the printer and then press 2 and then 4
Sep 29, 2009 | HP Office Equipment & Supplies
HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Al-1540 only scans, wont print says-data could not be sent to pri
it seems that the computer was trying to send the data to the printer through the wrong port. i went to the control panel in windows xp, and selected printers and scanners. and added a new printer (manually) as al-1540 cs on usb port 2. it alerted me that the software was not signed, i proceeded anyways. it asked if i wanted to keep the original printer , i said yes. and the test page printed away. so i would suggest people with similar problem to keep adding multiple copies of the printer again and again on usb ports 1,2,3... etc till it prints the test page. use the copy no. indicated in the printed test page to do all your print jobs in the future.
Dec 09, 2008 | Sharp AL-1540CS All-In-One Laser Printer
Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
Nov 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
Dear, after changing the cartridge, printer print a test print. OKAY. Take that test print and put it on the scanner (printed area should on the side of mirror) then press "scan" button on your printer "bottom left". When the light stop fluctuating. Keep out the paper from the scanner. After this Printer will work properly
Sep 09, 2007 | HP PSC 1315 All-In-One InkJet Printer
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
