Question about Microsoft Windows XP Professional
Microsoft Windows XP... Problem:
FILES ARE BEEING LOADED HOWEVER WHEN IT COMES TO REBOOT,COMPUTER DOES NOT TAKE ANY COMMAND.
R K SHARMA
rks_4000@rediffmail.com
  • Anonymous Jun 18, 2008
    i want to open hotmail but it is not open in my pc i dont know why so plz. suggest me .
    and i was install msn massenger but its also not support why?
    plz. give me ans.
    www.hiteshpachouri@gmail.com
  • John Galbraith
    John Galbraith May 11, 2010
    Are you able to Press F8 on bootup and get into safe mode?
Application error-xo8wr9.exe
Posted on Jun 15, 2008
  • 23 Answers
Go to your command prompt and enter "Fixboot". Be very careful when answering a prompt. Command prompt is unforgiving and you will loose everything and have to reinstall your system. Make sure you backup the folders and files you want before trying this.
Posted on Jun 11, 2008
Windows\system32\hal.dll. corrupt
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed:Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    Enter Load Identifier:
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    Enter OS Load options:
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 19, 2013 | HP OmniBook XE3 Notebook
Emachines T4010 won't start up, says image checksum, and that an image is corrupted
Receiving a bad image checksum error message when upgrading a computer to Windows XP means that a Windows system file such as user32.dll is damaged. This error occurs when any damaged system file is encountered that isn't overwritten during Setup. The repair process for this error involves voiding the damaged dynamic link library file from the DOS command line prompt and replacing it with a new copy from the Windows XP disk.
Insert a clean Microsoft Windows Millennium Edition (ME) or Microsoft Windows 98 Edition startup disk into the computer, and hold the reset button on the front of the computer until the system commences rebooting. Navigate the Windows startup menu with the keyboard's directional keys and select 'Start Computer with CD-ROM Support'. Hit "Enter" to continue. Write down your CD-ROM's drive letter on a piece of paper. At the command prompt, type "Drive:" without quotes (Drive should be replaced with the drive letter on which Windows is installed), and press "Enter." Type "cd windows\system32" without quotes, and press "Enter." Type "ren user32.dll user32.old" without quotes and again press "Enter." This renames your damaged user32.dll file so it is not recognized by the system, but still physically exists as a backup if needed in the future. Eject the Windows ME or 98 disk, and insert the Windows XP disk. At the command prompt, type "extract CDROMDrive:\i386\user32.dl_ Drive:\windows\system32\user32.dll" without quotes, replacing CDROMDrive with the CD-ROM's drive letter that you made a note of earlier, and replacing Drive with the system's drive letter on which Windows is installed. Hit "Enter" to execute the command. This process extracts a new copy of the user32.dll file to your hard disk, from the Windows XP CD. The new file will be found in the Windows/System32 directory. Restart the system by holding the reset button on the front of the tower until reboot commences.
Jan 03, 2013 | Computers & Internet
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
My new pc turns on but i cannot get the icons to show up
Hi lwoodward...
Try this solution, you may want to print to paper for a hard copy
Please rate me
Please follow these steps:
reboot your computer in the Safe mode with command prompt.
Once Windows loaded, command prompt (black window) opens. Type notepad and press Enter.
A notepad window opens. Type the following text into notepad:
[Version]
Signature="$Chicago$"
Provider=Myantispyware.com
[DefaultInstall]
AddReg=regsec
[regsec]
HKCU, Software\Microsoft\Windows\CurrentVersion\Policies\System,DisableRegistryTools,0x00000020,0
HKLM, Software\Microsoft\Windows NT\CurrentVersion\Winlogon,Shell,0x00000020,"Explorer.exe"
Save this as fix.inf to your Desktop (remember to select Save as file type: All files in Notepad). Close Notepad.
In the command prompt type Explorer.exe and Press Enter. Windows Explorer opens. Locate the fix.inf, click right button and select Install. Close Windows Explorer.
In the command prompt type shutdown -r and press Enter. Your computer will be rebooted and your icons should reappear.
Aug 29, 2011 | Computers & Internet
My netbook will not start because is says that the following file is missing or corrupt. &lt;Windows root&gt;`system32`ntoskrnl.exe . It says to reinstall a copy of the file but i do not know what...
hi
perapre yourself with your Winodws OS disk
then carefully read and follow these isntructions.. patience is required to sucessfully resolve this issue.
To resolve this issue, use either of the following methods.
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 3 loadTOCNode(2, 'resolution');
    For Uni-Processor systems: expand :\i386\ntoskrnl.ex_ :\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand :\i386\ntkrnlmp.ex_ :\Windows\system32\ntoskrnl.exe Note In these two commands, the placeholder represents the drive letter of your CD drive, and the placeholder represents the drive letter of the hard disk on which windows is installed.
Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Jan 09, 2011 | Computers & Internet
My toshiba A15-S127 has dimed screen and a friend habe reformated 2 times, , it send a message that read missed file or damage system32 foskrnl.exe , if I plug outside monitor it's how i can read the...
  1. Insert the Microsoft Windows XP CD into the computer. Note: If you have a system recovery CD or restore CD (not a Microsoft CD) these steps will likely not work for your computer.
  2. Reboot the computer with the CD and press any key when prompted to press any key to boot from the CD. Once in the Microsoft Setup menu press R to open the recovery console.
  3. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  4. Once prompted for the password enter the Admin password and press enter.
  5. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  6. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt for the identified versions of Windows installed. When you receive this prompt press Y if the bootcfg command properly identified each of the Windows operating systems installed on the computer. It is important to realize this command will only detect Windows XP, Windows 2000, and Windows NT installations.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter Microsoft Windows XP Home edition.
    * Prompt to Enter OS load options. When this prompt is received type /fastdetect to automatically detect the available options.
  7. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
Dec 07, 2009 | Toshiba Satellite A215-S7422 Notebook
Internet explorer will not allow to go to secure settings
Cause:
  1. Keyboard issue
  2. Miscellaneous corruption
  3. Corrupt boot.ini file.
  4. Missing boot.ini file.
  5. Missing or corrupt ntoskrnl.exe file.
  6. Windows NT installed on a partition bigger then 7.8GB
  7. Corrupted hard disk drive or severely corrupted Windows
Solutions
Before trying any of the below recommendations it's recommend that you attempt to load the last known good configuration.(this can be done by tapping the F8 key while booting and selecting last known good configuration)
  3. Once in the Microsoft Setup menu press R to open the recovery console.
  4. Select the operating system you wish to use; if you only have Windows XP on the computer you will only have one prompt.
  5. Once prompted for the password enter the Admin password and press enter.
  6. Once at the command prompt type bootcfg /rebuild to start the rebuild process.
  7. The rebuild process will step you through a number of steps depending upon how many operating systems you have on the computer and how the computer is setup. Below is a listing of the common steps you are likely going to encounter.
    * Prompt to enter the load identifier. This is the name of the operating system for the boot.ini. For example, Microsoft Windows XP Home users would enter "Microsoft Windows XP Home edition".
  8. Once you have completed all the available options in the rebuild and are back at the prompt type exit to reboot the computer.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
  1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue.
  2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key.
  3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
  4. Select the operating system you wish to fix, and then enter the administrator password.
  5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
  6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
  7. Type exit to reboot the computer
Attempt to check the hard disk drive for any errors by running the chkdsk error. To do this follow the below steps.
  5. Once at the recovery console type chkdsk /r
  6. Once completed type exit and see if issue is resolved.
Jun 04, 2009 | Gateway GT5656 Desktop PC
Cannot open my computer, laptop model PCGK45.
thats simple ur windows xp is corrupted there is only one thing u can do that is put in the xp dvd and reinstall xp
Dec 17, 2008 | Sony VAIO K45 Notebook
Missing file or corrupt
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 3 loadTOCNode(2, 'resolution');
uparrow.gifBack to the top Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Jun 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Have on-scxreen keyboard when i sign up on computer, how do i delte it?
You can remove the onscreen keyboard on the XP login screen by unregistering the component responsible for the login keyboard.
Open up a command prompt, and run the following command:
regsvr32 /u "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
To enable it again, run this command instead:
regsvr32 "C:\Program Files\Common Files\Microsoft Shared\Ink\loginkey.dll"
You'll probably have to reboot for the changes to take effect.
Apr 21, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
37 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
