The GPS device should have a numeric passcode to do the pairing such as 0000 or 1234 - this should be displayed on the GPS device's screen. Using your phone, click on the recently discover GPS device and it should ask you to enter the passcode - the one displayed on the GPS. After entering the passcode and most likely pressing accept or something similar, the pair should be initiate and we should receive a message on the phone said it was completed. The above solution might vary slightly based on the model of your phone and the GPS device.
You can use the default 4 digit passcode which is '0000",just ensure you enter the same passcode on the other bluetooth device(a phone) which you are pairing with,but if its an earpiece device,simply type in the passcode and wait for the device to pair automatically with your phone.
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
By pairing your KU990 and another device, you can set up a passcode protected connection. This means your pairing is more secure. 1 Check your Bluetooth is On and Visible. You can change your visibility in the Settings menu. 2 Touch Paired Devices then New. 3 Your KU990 will search for devices. When the search is completed Refresh and Add will appear on screen. 4 Choose the device you want to pair with and enter the passcode then touch OK. 5 Your phone will then connect to the other device, on which you should enter the same passcode. 6 You passcode protected Bluetooth connection is now ready.
Using a Bluetooth headset 1 Check your Bluetooth is On and Visible. 2 Follow the instructions that came with your headset to place your headset in pairing mode and pair your devices. 3 Touch Yes to Connect now. Your KU990 will automatically switch to Headset profile.
If you have any questions you can try reading the manual here http://www.in.lge.com/Product/Manual/KU990.pdf
to pair your bluetooth first, turn the bluetooth feature on your phone to on.
Next, hold the call button on your bluetooth until the light begins flashing blue and red, this means it it in paring mode.
Third, find the 2XXplantronics device in your bluetooth options. Select this divice and enter the passcode (0000).
You are now finished and the bluetooth is paired.
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
