Question about Vacuums
The shaft on the motor for rotating the brush is not moving. It is a Kenmore Whispertone 12 VModel 116 3521290. I am suspicious of the Belt Protection system.
  • kenamy Nov 26, 2008
    i need to clean the brush on my whispertone vacuum. i have misplaced my manual and I am not sure how to take the power head apart to do so.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=661780
Generic problem for all Vacuums
Posted by tsnater on Jun 10, 2008
The shaft on the motor for rotating the brush is not moving. It is a Kenmore Whispertone 12 V Model 116 3521290.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you have a motor that is froze up and would be in need of some type of service, whether it be the fan(s) on the end of the motor, the carbon brushes are sticking and bound up, or the armature would be the last thing. Just be careful that the repair cost and labor do not exceed the cost of a new motor. The motor shaft should @ all times should spin freely. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 11, 2008
Vax 2300
If the roller brush cannot be rotated easily by hand, it is likely that debris is jammed inside the end caps.Make note of the direction arrows on the end caps as you remove the roller brush. You will need to know this for reinstallation. The end caps are fastened with stop nuts. Removal of one will allow the inner shaft to be extracted for examination and cleaning. An old toothbrush is a good cleaning tool. Reinstall the inner shaft and stop nut. Check for free rotation of the brush roller. Place a new belt over the brush roller and reinstall the brush roller, being careful to observe the position of the arrows on the end caps. Inspect the motor shaft and remove any old belt residue before installing the new belt on the shaft.
Jun 30, 2013 | Vacuums
Rollers not moving
A careful inspection is likely to reveal the belt that moves the rollers is broken or the rollers are jammed up with hair or fiber and cannot move---the jammed up issue usually requires no real tools but the belt will require that are where the rollers are to be opened up to get at the belt which usually slips on the shaft from a motor---tight fit.
Dec 17, 2012 | Kenmore 23313 Whispertone Bagged Canister...
Belt replace panasonic vac
Is it an upright? On mine it's very simple.
Unplug vacuum and lay it on floor so that you are looking at the rotating brush. Remove screws that attach the cowling. Remove the cowling. You will then see the rotating brush ends. One end will have the belt, or what's left of on the brush wheel. You will also see the motor shaft. The belt goes between the shaft and the brush wheel. Carefully remove the brush by holding both ends and pulling straight out. Place the new belt on the brush wheel and replace the brush. With the belt on the brush wheel, stretch it to fit on the motor shaft. Rotate the brush to make sure the belt is riding correctly at both ends. Replace cowling and screws.
Nov 29, 2011 | Vacuums
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
The brushes are not rotating
Well, there are a couple of things to look at.
1. With the cleaner running, and the hose switch turned to carpets (2nd position) press in the reset button and see if that re-engages the belt. No?
2. You might have a broken belt. When you tried #1, did the motor on the power nozzle run, was the light on? If your answer is yes, and your roller is not turning, then your belt is broken.
3. If these are not the problem, then you could have either a bad motor in the power nozzle, or a hose switch problem. Well, I hope that this helped any. If so, please let me know. Thanks.. Rene (the Vacuum Doctor)
Nov 18, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Belt keeps breaking.
your brush roller isn't turning unplug the vacuum and see if you can turn the brush roller and also notice if it turns freely or is it stiff,take the roller out and remove strings,carpet strands and hair.if you can pull the ends off clean the ends good and maybe add just a little drop of machine oil on the bearing on the inside the roller where the bearings are.clean the motor shaft.there is probably old burnt rubber on the motor shaft.you can use a pice of emery cloth ,clean it till you see the polished finish .but i would say your problem is in the brush roller and the motor shaft.i hope i was some help to you.can you please leave some feedback
May 03, 2009 | Kenmore Whispertone 29512 Vacuum
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Kenmore Whispertone
The cover over the light, push in on the sides to release the tabs, then remove 2 screws. Using a screw driver, put it in the slot, one on each side, from the bottom, pry up to release the tabs, cover will come off and you can get to the belt and brush roll.
Sep 30, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
239 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
