Question about GE Advantium SCA2001BSS Microwave Oven
Seems like electrical storm fried my Advantium??
I came home from a storm that had my power out for a few hours while I was at work. The Advantium was flashing crazy stuff on the display and it would not work at all. I unplugged it over night and when I plugged it in the next day it did the same thing. Continuously flashes a bunch of symbols that don't make any sense over the display and still doesn't work. Has anyone ever had this happen? Its less than a year old...and was put in by the builder in our new home.
Any ideas on how to fix or how to avoid in the future?
  • GE Master
  • 5,568 Answers
This is likely caused by a momentary surge from a distant lightning strike.
Take a look at some of these surge arresters:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=%22whole+house%22+surge+protection
Also, your local utility may have them available for lease for a modest fee.
Most of these devices come with an insurance policy that would have replaced your microwave if it had still been damaged.
If I was building homes in our lightning-prone area, I would always suggest the installation of one of these.
Posted on Jun 10, 2008
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
No power, i have power to the outlet but nothing on the unit works.Is there a fuse?
remove the cover ... look on the floor of the unit near where the cord enters the cabinet.
Oct 12, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave power seems to have died
My advantium 120 died and it has power to the oven but it does not work! does the oven have a fuse that i can change?
Sep 29, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium Oven - LED lights went out.
if anything like my own it is the led blub thats blowen - major hasel to change out - get some one who knows these cookers/ovens...
Aug 07, 2009 | GE Monogram ZE2160SF Convection /...
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave not heating every time...
You seem to be having a problem with the interlock device. when you close the microwave door it is supposed to hit a series of 3 switches to tell the microwave every thing is safe and able to run. you may want to take the control panel off and make sure those switches are ok. usually out of the 3 switches top and bottom should be open middle should be closed. you could check with the continuity side of your electric meter.
Let me know if you have any questions before rating me.
Nov 15, 2008 | GE Advantium 120 Convection/Microwave Oven
Advantium -- wont cook
The solution to this problem is to replace the magnetron. I had the same symptoms, and I got a used magnetron and replaced it. It takes some advanced electrical skill, and you have to disassemble the oven all the way to the inside stainless steel. I have the same exact model, manufactured in November of 1999.
Jan 13, 2008 | GE Advantium SCA2001BSS Microwave Oven
Advantium oven has no power
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or fuse holder.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 18, 2007 | GE Advantium SCA2000B Microwave Oven
Open Questions:
See all GE Advantium SCA2001BSS Microwave Oven Questions
GE Advantium SCA2001BSS Microwave Oven Logo
176 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
