Question about Frigidaire Refrigerators
Frigidaire the refridgerator is not cold enough. It stays at 60 degrees, I don't know the model because it was torn off inside the fridge and the owner's manual did not come with the house when we bought it. What do we need to do. It is a stainless steel side by side fridge
  • eric_johnson Aug 20, 2008
    Neither the refrigerator nor freezer are cold enough
Have one similar and found out the compressor goes out on them about a year and half after purchase. You can buy another compressor but the likely hood of it going out again is likely. Sorry but we bought bad fridges. Never again will I buy a Fridgidaire.
Posted on May 03, 2009
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Freezer section working properly, 0 degrees, fridge side not cooling enough, 60 degrees. Controls have not been changed.
If it's like mine, cold air from the freezer isn't reaching the fridge section, so you probably have one or both of 2 problems: the circulating fan isn't working and/or the air flow channels are blocked by frost/ice. The fan is probably inside a structure at the back of the freezer that should be removable to check it.
If the fan's running, you have a freeze-up. Solution is to turn everything off, remove food & wait for the ice to melt which will take several hours unless you speed things up with, say, a hand-held hair dryer. This worked for me!
If the fan's not running, you can find a replacement at your local appliance parts dealer.
Nov 04, 2010 | Frigidaire Refrigerators
Our refridgerator is not getting cold! it is staying at 60 degrees.. we tried cleaning out the back fan, and also tried resetting the temperature gauge but it keeps going back to 60 degrees and it...
Please double check your model number because that number is not listed. I am pretty sure it has a dual evaporator one for freezer and other for the fresh food compartment. Check behind the cover of the fan inside the fresh food compartment to see if the coils are icing over. Send me the correct model number will help me decide if it is something different. I will even send you a Service manual with the correctmodel number, Thanks, Sea Breeze
Feb 12, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Freezer won't go below 10 and fridge goes between 40 and 60 degrees
Ensure the condenser is not clogged with dust or other debris.
Ensure the condenser fan (usually found in back) is turning when the fridge is running.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer not staying cold
the temp control thinks its cold enough to stay off so you need to have the temp in home warmer so it will cycle / atleast 60 / larry
Dec 12, 2008 | Frigidaire FRT21H8 Top Freezer...
Whirlpool side by side freezer ice cold refridge only at 55
My frigidaire has a flapper valve assembly that opens and lets the cold air in from the freezer as required. The frigidaires are known for the flapper breaking and staying open and allowing too much cold air in to the refridgerator side.. Check yours out. Mine has a shroud at the top of the refridgerator. Remove it and look around, I feel sure you have the same problem.
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Frigidaire frige not getting cold but freezer working
my refridgerator is not getting cold but the freezer seems to be working fine. can anybody please give me some advice on what this could be. We had a new defrost element put in a few weeks ago and we now have moved house so fridge is cool but not really cold enough model E402B any help would be appreciated.
thanks pam
Apr 29, 2008 | Refrigerators
Refrigerator will not stay cold
Bought a second hand fridge that was running well. We layed the fridge on it's side for moving and let it stand upright for at least 4 hours. The moving was only 45 minutes. The freezer is semi-cold but the main body of the fridge stays at aprox. 68 degrees. Any solutions.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
344 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
