Question about Toshiba 52HM95 52" HDTV Projection Television
Another color wheel goes bad
I am looking for a source to replace the CW only on this model. It screamed so loud that I couldn't turn up the volume enough to cover it up. My service tech says that Toshiba said he has to replace the whole optical engine, which we both disagree with. Any ideas where I can get the color wheel only? Otherwise, the tech says the repair will be over $900.
Mike
  • Conko Jul 11, 2008
    I found a place called TriState Module (.com) that will rebuild the entire unit for $199. I guess that's what I'll do, and then sell the darn TV when I get it back. Never again, TOSHIBA! I guess that Toshiba stands for Televisions Only Stay Healthy In Brochure Ads.
  • 3 Answers
Our color wheel has gone bad twice in two years and the tech had to replace the entire engine. Luckily we bought the service contract and haven't had to pay for any of the many repairs to this t.v.
Posted on Jun 20, 2008
  • Toshiba Master
  • 8,617 Answers
You cant the HM95 is a combined unit like some sharps, you have to replace the entire engine
Posted on Jun 11, 2008
Samsung HLR5064W DLP TV, lamp timer light flashing, but there is a loud vibration noise like a fan blade hitting something at the back of the set. I replaced the lamp a couple of years ago, and I think...
Sounds like a bad color wheel----remove lamp---the wheel faces it--look for missing pieces or the wheel shattered---these are known for the wheel making a loud high pitched sound or even a grinding sound if the wheel shatters.
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.
Oct 24, 2012 | Televison & Video
Tv samsung hls4266w all light are blinking replace the blud small fan and large fan running
if wheel bad You Tube has video instructions for replacing it---seen several people able to do this themselves in about a hour. Google the model number to ("color wheel") to locate a replacement on the internet.10_24_2012_4_08_47_pm.jpg
Oct 23, 2012 | Samsung 61" Slim-Depth DLP HDTV
The tv hums, you can turn the volum down to zero znd the tv hums to loud
You have a Bad Color Wheel,that is what is causing loud humming sound.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts 1-800-627-4368
Color Wheel is Located Behind Lamp ,Pull Lamp out and with a Flash Light Look inside you should see Color Wheel. Color wheel spins 9,000 rpms per second
Apr 12, 2011 | Samsung HLS4676S Television
Samsung DLP TV repair or replace that is the question!
Color wheel sounds like it needs replacement. The set will often shut down when the color wheel gets bad and wont power up.
Jul 10, 2010 | Samsung HLN5065W 50" Rear Projection...
Loud rumbling/buzzing for 10-15 seconds and then power goes off
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
Mar 17, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Loud buzzing noise has gotten louder and we know it to be the color wheel as the fan has been replaced. How can we replace the color wheel?
Hire the shop to replaced the colors wheel,because if u replaced,and adjust it wrong,ur power will sutdown.Well cause more problems than same some money.
Jan 15, 2010 | Samsung DLP HL-P5663W 56" TV
Loud whinning, high pitch noise coming from TV when turned on.
The color wheel is likely bad and needs to be replaced.
Check this link it is for a samsung TV but the same principals apply
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
Oct 17, 2009 | RCA R52WM24 52" HDTV Projection Television
Samsung DLP HLR5667wx/xaa. All sudden loud noise non stop
This sounds like you may have a bad color wheel. If you want to change this yourself you need to be aware that even with the tv unplugged there are still dangerous voltages in the set.
Changing the color wheel is an involved repair the wheel it's self is very fragile to handle, they can be purchased on line from many sources.
The cost from a service center would be a normal service charge plus about $150.00 for a color wheel. If you have a service center come out to your house explain your problem clearly and they will know they need to bring a color wheel, it will prevent the tech from having to make a second visit.
Sep 05, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a samsung HL R5067W DLP TV. the fan makes loud noise and runs eradically (spins up and spins down) any suggestions? Is fan bad?
Hi, have you removed rear covers and verified it`s one of the fans ? Those sets are notorious for loud color wheels, we have replaced 2-3 fans but we`ve replaced 50 color wheels, light engine has to be pulled to replace cw so call and get an estimate first so you can verify which has failed but my moneys on the color wheel, good luck, video-tek
Jul 01, 2009 | Samsung Televison & Video
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
148 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
