Question about Brother IntelliFAX 2800 Laser Fax
Change drum soon will not clear after new drum inserted
Change drum soon message will not clear after new drum inserted
  • Anonymous Apr 02, 2009
    I agree with solution #2: this is not the procedure.
  • telecom125 Apr 29, 2009
    I HAVE A BROTHER INTELIFAX 2920....CHANGE DRUM SOON MESSAGE WILL NOT CLEAR AFTER INSTALLING NEW DRUM....HAVE TRIED 2 NEW DRUMS, NO CHANGE.....HAVE TRIED DRUM FROM ANOTHER MACHINE, NO CHANGE
This is not the correct procedure, it does not work
Posted on Sep 25, 2008
Reset of the drum counter
Open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
Hope this helps...
Posted on Jun 12, 2008
How do i reset ricoh sp 1200s drum unit
why toner life end message keep on showing on sp 1200s prints.
Aug 04, 2012 | Ricoh Office Equipment & Supplies
Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
hi
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
  3. Press 1 to reset the drum count.
  4. Close the front cover.
Oct 07, 2008 | Brother Office Equipment & Supplies
How do you change the drum on a Brother IntelliFAX 2920?
Open the front cover.Pull out the drum and cartridge unit.Unlock the toner from the drum with the blue clip.Take the new drum remove all the pacaging material insert the toner in the new drum.Replace the drum and toner unit back in the machine.While the cover is open,press the clear button.The machine will display "Replace drum yes or no" Select Yes.Close the front cover.
Dec 07, 2009 | Brother IntelliFax-2920 Fax
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Jun 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 2820 -
With the front door open hit the clear button. It will say new drum? Choose yes and hit the set button. Your all set. Lawrence
Dec 29, 2008 | Office Equipment & Supplies
FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Nov 13, 2008 | Brother IntelliFax-2820 Laser Fax
Change Drum Soon still shows after changing the drum unit
After changing the Drum, open front cover and press "clear" then press "1" to reset.
Jul 22, 2008 | Brother IntelliFAX 4100 Laser Fax
Continous 'change drum soon' message after I change the drum.
5750e fax machine: To reset the drum counter follow the instructions listed below :
Get the message to appear in the LED
2. Remove and Re-insert Drum/Toner unit
3. Press the CLEAR key.
4. Press 1 to reset.
5. Close the front cover, pressing firmly on each side until they click
into place.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000007572&Sympt=Why+does+the+message+CHANGE+DRUM+SOON+continue+to+appear+on+the+LCD+display+after+I+replaced+the+drum%3f&Model=58&ProductGroup=2&Keyword=Change%20drum%20soon%20message&ProductID=PPF5750e
Jul 08, 2008 | Brother Office Equipment & Supplies
This machine is reset with a plastic sheet that come in the new drum unit. When the drum is inserted for the first time, the sheet slides out and trip the exit sensor in a certain way. Then the counter is cleared. If you still have this clear plastic sheet, then you can reinsert it into the top of the drum unit and try it again.
Jun 30, 2008 | Brother MFC 4800 All-In-One Laser Printer
How do I reset the Change Drum Soon on the display?
All you should have to do is: -replace the old drum with the new replacement. -with the front door open press the Clear/Back button -press the number 1 button and when ?accepted? appears on the LCD close the front cover. That should do it. Let us know if you have any other questions and please don?t forget to rate this post.
Feb 28, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
1,572 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
