Question about Denon AVR-2105 Receiver
Over heated after the unit had been on all day, i noticed that somebody put some books and papers ontop of it ( covering the cooling vents ). i could smell something burning. now when i turn it on the stand by button/lightflashes 5-6 times then clicks and just flashes red. please advise.
  • davezilla Jun 10, 2008
    no warranty. i was expecting to simply replace a part.
    would there be a logical place to start? assuming that it did overheat, would this be obviuos by just looking at it?
  • Denon Master
  • 13,433 Answers
The manual warns not to put books on it, do you have warranty?
It might not be covered by the warranty.
Posted on Jun 10, 2008
    Master:
  • 555 Answers
Is this unit still under warranty?
Laptop freezes beeps
Is it up on a table on in your lap?
There are vents on the sides and bottom that need to be kept clear so the unit can cool itself, you can visually inspect those to make sure no dust/dirt are clogging them up and use compressed air to clean.
If you are snuggling in bed with it or have papers close to side of vents, or using in lap covering those holes, you should feel the heat, heat destroys laptops and if you continue to use it in that manner, if that is the issue, you will have a failed unit shortly.
It is most likely beeping and shutting down from excessive heat.
Oct 29, 2013 | Toshiba Computers & Internet
Goodman Heat Pump laing heat and loud noise
Taking a little bit of time for heat is normal but the "pressure" thing you are referring to leads me to believe that the reversing valve is getting stuck. You will here that "pressure release" noise with a reversing valve but it should not be happening 5 minutes after start up.
May 06, 2017 | Goodman Heating & Cooling
My new Coleman Mach 15 seems to be having a hard time cooling when the heat hits. I have a tstat gun to check to temp of the air coming out of the vents. In the morning when it is cooler, it is cooling...
check and see if someone has not installed a filter on the return .. The it sounds as though your in the sun for the heat of the day. I also sounds as though it may be a bit low on gas . Remember that these unit are kinda a one size fits all arrangment. as they are travel trailers. But you should be able to keep it to a 45-55 degree supply air . If you can i would move it to a shady spot for the afternoons if possible.My unit take 2 ac to cool it on hot days and its insulated for cool climates . again 40-45 degree discharge should be what your looking at in the cool of the mornings.. Hope this helps a little.
Aug 07, 2011 | Coleman Mach 15 Air Conditioner
Intertherm Gas Furnace MiMB 077ABW We have just had this furnace and heat pump installed and we find that it takes at least 1 1/2 to 2 hours in the morning to bring the heat up from 15 Celsius to 21.5...
Yes it is. I hear that all the time how this unit does not heat/cool like the old one. Energy efficiency, variable speed motors, your pocket book will thank you!!
Aug 10, 2017 | Heating & Cooling
I have a 20 year old Trane heat pump. Outside
Yes, you will want to put the unit into cooling mode to help assistance with the ice melt.
If you can, block off the outdoor coil or disconnect the outdoor fan motor. This will assist in raising the discharge pressure and temperature and thus, it will melt the ice quicker.
Or, if you have the capability, you can take a garden hose around to the unit hooked into hot water and melt the ice that way.
If your control board is messed up, why aren't you replacing it?
Jan 10, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My attic air conditioner will stay at 81 degrees in the hottest part of the day only when it is sunny when it is cloudy it works fine I have a small 900 sq foot ranch
if the difference in termperature is between 15 and 20 degrees between the inlet and outlet, the unit is doing all it can and is undersized. if not check for airflow problems, filters, dirty coils etc. and if that is all good, then there may be issues with the refrigerant charge
Jul 12, 2009 | Dometic Rooftop RV Air Conditioner
Outside air temp around 100 unit wasnt cooling good noticed evap coils dirty cleaned them cooled alittle better checked low side showed 90 lbs had friend reclaim to get it to 70 lbs 30 minutes later it...
90 psi suction too high possible bad valves or non condensablies in the system (AIR) what is the head pressure and what type of freon r-22 410-A? your unit is never shutting off watch out for that electric bill. and did you take apart the condenser and clean it? Tom
Jun 25, 2009 | Heating & Cooling
Central air/heat pump not putting out cold air
I have some things for you to check. If you look at the outside unit the lines going into the house. Are they frozen? Have you had any yard work done, the reason I ask is they could have accidentally cut or pulled out the thermostat wires to the ac unit. Also, inside check for the same thing, frozen lines. Also, you may want to check the drain coming from the inside unit, it may be clogged.
Jun 22, 2009 | Heating & Cooling
Hot Upstairs
A good heating guy should be able to balance your dampers to increase the airflow upstairs. Keep in mind heat rises. 2nd floors are the hardest to cool. You may need to add more returns to pull the heat down the the evaporator so it can be cooled. If you are lucky you may be able to adjust your blower up to a higher speed. You may have to even add some more supply airs. Check with your local building inspector. He may be able to give you a list of contractors in your area that would be good for this type of problem. Good luck>>>
Apr 02, 2009 | DeLonghi Pinguino PACL90 Portable Air...
EVerstar Portable A/C
I have the same problem how can i solve this problem>
Sep 03, 2007 | Danby DPAC8020 Air Conditioner
Denon AVR-2105 Receiver Logo
85 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
