Question about Frigidaire Dryers
MY on/of knob is broken from the part that is insede the head of the dryer, can I replace this easily?
  • suzie617 Jun 11, 2008
    Dear ol_lonely:
    my knob broke part of the piece that hold the knob, I have part attached to the knob and the other part is in the dryer, I tried to pull out the part in the dryer but with no luck. any suggestion on how to take out the part that is in the dryer head? thank you in advance.
  • suzie617 Jun 12, 2008
    Dear ol_lonely:
    thank you so much for sharing your knowledge. I will check the dryer as you recommend and see if i can remove the switch.
  • 77 Answers
Most dryer knobs just pull straight off. be sure to get all the pieces off the shaft(small black spring clip on some??). new knobs are easily obtained from any parts house and push on.
J
Posted on Jun 10, 2008
  • Jim Gillon Jun 12, 2008
    if the shaft broke off, you will need to replace the switch. that can be accessed from the back of the console. unplug unit and remove plate on back of console, switch is usually screwed in from front or rear, sometimes they have a tab and twist in. you need to examine closely to determine method used to attach to console then when removed examine condition of switch and knob.
    J
The Magic Mill knobs are broken and don't turn easily, because the inside loop cracked is there anywhere I can purchase new ones at a reasonable price?
Our knob broke on back side on our dryer, I just took the old knob to the appliance repair store and see if they could match it up, they did. God-Bless!
Jun 03, 2016 | Dryers
The knob assemble is broken tne part that turns the shaft can i get a replacement
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 18, 2010 | Danby DCD5505W Electric Dryer
Direction arrow does not work can it be replaced?
Maybe easily fixed... Take the head apart...just 3 or 4 screws up from the bottom. The direction arrow is "driven by a plastic gear that may have a "C" type ring holding the arrow and the gear together. The arrow sits on top of the gear like a car radio knob sits on its control shaft...with knurled splines. If either one is stripped or broken you'll have to purchase a new head housing...around $50-$60. Good Luck and God Bless
May 11, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
DRYER RUNS IN OFF POSITION BUT NOT ON CYCLE POSITION
It could be that the knob came off and someone pushed it back on in the wrong location. Knobs are keyed so they should only go on one way, but since most knobs are plastic and can get messed up fairly easily, you might want to pull the knob off and see if that is the issue.
You might need to get a new knob if yours has gotten a broken socket where it slips onto the control shaft.
Hope this helps. Best Regards!
Aug 01, 2009 | Maytag Dryers
Starter Knob broken
go to sears .com,click parts put in your model number(should be inside the dryer door)and get your part.or repair clinic.com-mike
Apr 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
I bought a frigidaire dryer knob to replace the broken one. But how do I get the knob on without hammering it and cracking the knob and stem? the stem on my frigidaire dryer is broken - i have the knob...
You will want to take out the screws on the back of the dryer behind the control panel. Once off you will see all the wires and such connecting to the timer and the knobs. Make sure you disconnect the power first before digging in in there. When you find the spot that your knob goes take that control part off and place your knob in. Once you have the back off you will see how it goes on. If you have any other questions feel free to ask me and please let me know if this was helpful to you. Good luck and glad I could help.
Jan 22, 2009 | Dryers
Dryer knob sticks in one spot- won't move
 Door switch / Door switch actuator leverThe dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Oct 25, 2008 | Maytag Clothes Dryer Almond Timer Knob...
How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryers Logo
73 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
