Question about Tappan TGF320 Gas Kitchen Range
Tappan Millenia - oven door locked can't open
I accidentally hit clean instead of clear. I got the clean function to stop before it inciderated my bread, however I can't get the oven door open. I cut off power to the stove for 5 minutes hoping for reset. Nope. I did hit clear and many combinations of buttons.
help
  • cmhassenstei Jun 18, 2008
    Same exact scenario, oven door locked and cannot open
  • Anonymous May 11, 2009
    same exact thing !!!
How do i open my tappan computerized over when close and won't open
Posted on Sep 07, 2010
My kenmore 46745 or 46749 (both models listed on the manual) door is jammed. I accidentally opened the oven door, stopping a cleaning cycle after only 15 seconds, and now the door will not close...the lock...
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Nov 26, 2010 | Kenmore 45781 / 45782 / 45784 / 45789...
My oven door shows locked. this happened when i tried to clean oven. the door will open but shows locked. how do i clear the door locked?
The board is either confused and you can just unplug this unit and let it sit for 30 minutes then plug in and reset. its possible, it will be okay....or did you actually clean the oven and the door opens , but lock light is lit? if this is the case and it cleaned, and you can open the door. I'dsay you have a problem in door latch to door light switch causing this condition
Nov 26, 2010 | Tappan Kitchen Ranges
Locked oven door
Look for a button or sensor which the door would press when closed.
If you find it hold it down for a minute, this should reset the lock
if it doesn't it may do when you let go
May 12, 2008 | Kenmore 95680 / 95681 / 95682 / 95684...
Oven door won't unlock
I had the same problem on my Kenmore Electric Range. Door would not unlock. Tried pressing "Off" for multiple seconds, but still would not unlock. No error codes. Clock was displaying normally. Finally decided to try running it thru the self cleaning operation to get it to cycle thru locking and unlocking the door. When I started self clean, the door automatically went thru the auto lock and "locked" appeared in the display. I then hit "Off" to clear it and stop the cleaning cycle. The door then unlocked as normal!
Feb 16, 2008 | Kitchen Ranges
The oven door of our Tappan locked accidently.We tried to cancel but there were no results.
what do you mean locked accidently if if the door is locked and 3hrs is on the display hit start then cancel if the door showes locked and is not (you can still open the door)push in on the door switch by hand and push cancel let me know
Feb 13, 2008 | KitchenAid KESC307 Electric Kitchen Range
Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
Dec 31, 2007 | Frigidaire PLEF398AC Electric Kitchen...
DCS gas oven locked
I let the door stay open, hold the switch closed with my finger, activated self clean. Let it run for a minute then hit cancel, the stove heating element shut off and the locked door blinked for 5 seconds then finally stopped. Back to normal.
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Tappan Electric Oven
I have a Tappan double oven range. An older model #316065301
How do I operate the cleaning cycle? I set the start and stop times, Locked the door and switched to clean. The clean light comes on but it doesn't heat up much at all. Never locks. I have misplaced my instructions manual.
Any help would be appreciated.
Barbara
blueznmooz@aol.com
Nov 19, 2007 | Tappan 30IN ELEC IGNa Oven
Range oven door
try holding the door switch closed and press cancel. that usualy takes care of it. if that doesnt work send your model number out and this will help.
Sep 26, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Tappan TGF320 Gas Kitchen Range Logo
908 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
