Sony tv my tv won`t turn on either by manually or by remote. i checked outlet and power plugs.
  • 3 Answers
Do you feel static on the front of the screen (indicating the high voltage is working)? Put your arm in front of the screen when you hit the power button and see if your hairs are being pulled towards the screen.
Posted on Jun 10, 2008
TV WILL NOT TURN ON
      NOTE: If the TV turns on and off using the POWER button on the TVbut does not respond to the POWER button on the remote control, troubleshoot the remote control. Unplug the TV power cord from the electrical outlet for 30 seconds. Plug the power cord into a known working electrical wall outlet.Aug 15, 2015
      The TV will not turn on or does not have any power. - SONY
      https://us.en.kb.sony.com/.../the-tv-will-not-turn-on-or-does-not-have-any-...
    Feedback
    TV Will Not Turn On - Troubleshooting Help for Finding ...
    ? 2:32
    https://www.youtube.com/watch?v=kEDVc-BXf0I
    May 1, 2014 - Uploaded by ShopJimmy.com
    TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and causes of ...
Jan 14, 2016 | Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Tv won't turn on
Have you checked whether the power outlet is ok? Have you tried connecting the TV to another power outlet? If so, there is a defect inside and should be handled only by a qualified service technician.
Aug 13, 2012 | Sony KDL-52W5100 TV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
I have a sony trinitron (the heavy one, that has a flat screen, but isn't a flat t.v.) And it won't turn on. It makes the initial sound that it's turning on but then there is no picture or sound. There is...
The Standby light LED flashing at the front panel of the TV is the self diagnostic display which can be easily identified by a service technician by counting the number of blinks.
  • You can try power resetting the TV by removing the TV from the power outlet and remain unplugged for 1 minute. This will reset the internal parts of the TV.
  • Disconnect all the components connected to the TV and check if the TV works normally.
  • If the television is plugged into a power strip or a surge protector, remove it from the power strip or a surge protector and plug it directly into the wall outlet and check the operation.
  • Try resetting the TV back to factory default. Resetting procedure using the supplied Remote is listed on the supplied manual. The resetting procedure of the TV differs with the model.
If the issue persists after the possible troubleshooting, get it serviced at a Sony authorized service center. Check if the nearest service center is offering a Home Service.
Good Luck KenSolutions
Nov 23, 2010 | Sony Televison & Video
Won't power on! is this something simple or do i have to move on ?
if won´t power on manually or using remote control, may be you have an power supply or horizontal output trouble, first check that your outlet is powered with something, use an radio for example.
Mar 17, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
Sony kf50xbr800
juzz i suggest that u would unplug the unit for a couple of minute the plug it back in on a wall outlet.use the tv/video button to change the video input if that button didnt work it may require service....jake
Dec 07, 2006 | Sony Grand WEGA KF50XBR800 50" Rear...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
Electro Med Services...
