Question about Nikon Speedlight SB-600 TTL Flash
Flash unit wont come on
Hi, I had a AA battery leak and now the init wont work. Any tips?
  • Anonymous Oct 09, 2008
    I had the same problem with a battery that leaked. My fault I did not unpack my flash after the last outing. It took quite a few swipes with the vinegar and Q-tip but it did eventually work. I was ready to pack up the SB 600 and send it back to Nikon. I kept switching out the batteries, trying it again, cleaning again and eventually it worked.
  • Anonymous Nov 16, 2008
    Yet another successful repair using vinegar on a Q-tip. Thank you for the fantastic advice!
    President:
  • 423 Answers
If the contacts on the battery door, or down inside the flash have green or white gunk on them, you can remove it by using the eraser on the end of a pencil. If the stuff is really stubborn, dip a cotton swab in vinegar and wipe it all over the contacts. If the stuff is white, you will see it bubble away, if it's the green stuff, let the vinegar soften it, then dry it all up with another swab. That usually does the trick.
Posted on Jun 12, 2008
It works, Thanks ! The unit now smells like vinegar, I should have picked balsamic.
Posted on Nov 07, 2008
Thanks for the tip! it worked for me! was sooo worried it won't work anymore.
Posted on Oct 28, 2008
It worked!!! Steve your da man! BK in da house!!
Posted on Aug 29, 2008
I had the same problem. The bottom contact was dirty due to battery leak. Hard to see until I read this. It worked. Many thanks.
Posted on Aug 19, 2008
How do the batteries come out of a vivitar 102 flash
This is a wonderful flash unit that I had the privilege to own many years ago. The battery door is in front of the hot shoe. Slide it forward or in the direction of arrow and allow it to swing down. Four AA batteries should fall out or slide in depending on whether there are any already there.
Sep 25, 2014 | Vivitar Automatic Auto Electronic Flash...
My Nikon coolpix l20 wont turn on and the batteries are fine. What do i do?
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Nikon COOLPIX L20 Digital Camera
Canon A720 IS camera will not take a picture when flash is turned on but will if flash is turned off. I see a flashing flash symbol in the LCD panel (as if it is waiting for the flash to charge) when...
Dear sir,
It seems  ur battery is weak , since it  use  AA battery put new alkaline batteries  & then try .. I beleive it will take pictures  with snap .
Regards
Raj@npconline.in
Feb 12, 2011 | Canon PowerShot A720 IS Digital Camera
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nikon digital 1-800-645-6689
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
A580 wont switch on with new correctly inserted batteries
Check for battery current ratings, Canon cameras need AA batteries with current rating above 1200 mAh, I use Energizer rechargeable batteries for my Canon Powershot SX110 IS. The batteries last more if we use the flash option wisely.
Jul 25, 2009 | Canon PowerShot A580 Digital Camera
Vivitar 285HV Stop Working
There is nothing wrong with your flash unit. The regular AA batters are 1.5 v volts each- if 4 batteries are used that is a total of 6 volts for proper operation. The rechargeable batteries are 1.2 volts each and 4 will get you 4.8 volts- thats 1.2 volts short and that is probably the root of our problem .
Try recharging you rechargeable batteries and put the im one more time- if the same problem happens you will have to stick with standard AA batteries. There external 6 volt packs that will work with your flash unit0 the are a bit of an expense at first but you will save on replacement batteries in the long run,.
Ed
Nov 27, 2008 | Vivitar 285HV Flash
Does the Cullman 25cb auto flash unit use batteries......
The Cullman 25 CB needs 3 AA batteries. The upper part of the back with the dial is shoved up to open the battery case.
Feb 04, 2008 | Cameras
Wont start
try new batteries, does the unit have a reset?
Nov 26, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Red Flash mark while taking photo
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Oct 12, 2007 | Olympus FE-170 Digital Camera
Going through batteries abnormally quickly
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
May 31, 2006 | Canon PowerShot S1 IS Digital Camera
Nikon Speedlight SB-600 TTL Flash Logo
416 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
