Wireless card problems
My wirless signal strength keeps going from top to bottom all the time and disconnecting me within seconds
  • russilpark Jun 22, 2008
    My computer doesnt recognize my internal wireless card. I have used a wireless g router in the past, but I recently connected linksys back up and I have no wireless capabilities. I looked in my drivers to fix the problem, but the driver for wireless is gone. What can I do?
  • kalpesh jain
    kalpesh jain May 11, 2010
    tell me first which o/s u useing and which wireless adapter r u using all those details give us then we can help you
  • 611 Answers
Do one thing your wireless keep to bottom then you get the top
Posted on Dec 12, 2008
Keeps Getting DIsconnected from network
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Mar 18, 2013 | D-Link Computers & Internet
I have a acer laptop the keeps turning off wirless connection
Aug 20, 2012 | Computers & Internet
I lose my wirless signal on the internet
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Feb 17, 2012 | D-Link DIR-615 Wireless Router
Not getting good signal strength frm router with wirless computer
There are signal boosters and repeaters available, but generally run in the $250 range for decent ones. What you can do is get a wireless access point installed. It requires an ethernet cable to the router to connect it, but you can put that in the house close to where you are and feed off of it.
Jun 14, 2009 | 2wire Computers & Internet
Wireless network on and off all time
Plz check ur signal strength first. Second u can check with configure ur wirless adapter properties with static speed (802.11b or 11Mbps).
u can check ur wireless adapter on ur bro's laptop, disable his WiFi button & connect his laptop through this wireless adapter to samsung modem.
If the problem remain same on ur bro's laptop then ur wireless adapter having some problem.
PLZ GIVE RATING BY YES or NO.
Mar 20, 2009 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Low to no signal strength
Try agusting the wirless properties for your wirless card. You will need to go uder start then go to conect to and the show all conecsions. The you will need to right clcik on the wirless conecsion and go to properties. Now you will click the button that says configure. I hope this helps
Jan 01, 2009 | 2wire HomePortal 1800HG Router...
What virus checker are you using? Is there also a different firewall apart from the windows one. If you have blocked your connections it will prevent you from using your wireless effectvely. Uninstall or disable the virus checker and see if the same happens. Also are you using E internet, try mozilla firefox and see if the same happens.
Another thing to check is if the adapter is using the windows manager properly. What you need to do to check it follow the following instructions.
  • Click on start and choose CONNECT TO option and click on your wireless adapter. (Wireless network connection)
  • Click on View Wireless networks
  • Scroll on your network connection and then click on change advanced settings
  • Now double click on Internet Protocol TCP/IP
  • Make sure both settings are set to automatically detect DNS address and IP address
  • Then select apply if need to change and ok to continue
  • Now click on the Tab Wireless Networks
  • Wait a few seconds and Now make sure the top box which says "Use windows to configure my wireless network" has a tick next to it, if now click on box.
  • Click on Apply and ok, or just ok if no apply option
  • Close all windows and restart computer.
  • Now see if the device connects and click on your browser and see how it works.
Any questions if still not working please give details.
Jul 09, 2008 | Linksys WPC54G Wireless-G Notebook Adapter...
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Dec 24, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Poor signal strength
have a go at changing the wireless channel within your router there may be some interfearence generated by your pc that is affecting its signal strength
Oct 29, 2007 | Computers & Internet
Computers & Internet Logo
158 people viewed this question
David Payne
David Payne
