Question about True GDM-9 Beverage Cooler
The inside is hot
The inside of the cooler is blowing heat, all items are now close to hot not cold. The unit was serviced 2 months ago; the problem was that the vent was covered in dust or whatever, so they cleaned it with an air compressor. But now that is not the problem. All of our drinks are warm and the unit stays on.
    Novelist:
  • 112 Answers
A couple of consequences to a dirty condenser. First the compressor could have blown a valve. Second the cap tube and/or liquid line drier could have clogged - If the unit has R-134A this is more common than not.
Of course there is also the possiblity that the dirty condenser had little to do with the original service call and that the unit is low on refrigerant or has a faulty thermostat.
Posted on Jun 06, 2009
The unit squeaks whenever turned on, no matter what level the fan is blowing (Lo, Med, or Hi). Started about a week and a half ago.
A rhythmic squeak sounds like either a fan motor bearing going bad or just vibration from the unit running thats wiggling something loose inside the unit.
Jul 23, 2015 | Everstar Portable Air Conditioner Everstar
Tip
Haier Thermoelectric Wine Cooler
This wine cooler hasn't held temperature for months, even though during the winter my living room gets to 58 F at night. I've had it maybe a year.
I took the back off, and 2 of the 3 heat sinks felt cool, which means the thermoelectric pack was just conducting cold out of the cabinet in 2 of 3 cases. The third one felt slightly warm, as it should. I checked that the cool ones had 12 v to them, they did, so they should have been pumping heat out.
I put bowls of ice inside the unit, and when the temperatures got down to the set points, I heard relays click, so I figured the control unit was OK.
I removed one of the TEC modules that was cold on the outside, and taped up the hole with masking tape.
I unplugged the fan from the circuit board and unscrewed that fan assembly from the heat sink.
I then clipped the leads to the TEC unit, cut away the blobs of hot melt glue, and disassembled the cooling module. I took the TEC device and hooked it back up, making sure it had voltage to it. After awhile, both sides just felt slightly warm so I knew it was bad.
Got on line and ordered 4 (to have spares) TEC1-12703 coolers. I have thermal grease. When the parts come, I will re-assemble and should be good to go.
I don't know what blows the TEC devices, they should be very robust. Maybe Haier got a bad bunch of them, I read almost all bad reviews on these wine coolers.
on Apr 03, 2010 | Haier HVTB40DPABS Wine Cooler
I have no air blowing from the vents,hot or cold ?
check blower motor fuse Hope you put in a thermostat that ceases open and not closed like the cheap ones.
if the blower is blowing and no air ... then its the vent controls ..not knowing what the truck is ... it could be mechanical or electrical or vacuum.
Jan 08, 2014 | Cars & Trucks
2003 ford expedition i just got it a week ago and the front heat works great but the back vents only blow cold air. How do i fix this?
With the car parked and engine idling, turn the ventilation control between windshield defroster and "open air ducts" to front and rear vents. Listen to pinpoint where the valves are that open and closes the air ducts. It sounds like the air duct to rear vents are blocked, and the cold air in rear air duct is coming from "outside ventilation." The air vent to allow hot air to the rear vent is stuck in "open ventilation" mode, like when you're driving in spring or summer months.
Nov 29, 2013 | Cars & Trucks
My Vulcan bonair evaporative cooler when turned on is making noise like its working but no air is coming through the vents. The pads disintegrated a few weeks ago and came through the vents. Has worked...
I would think you have to get new pads for it, they hold the water so the van can blow the moisture through them and then into the air. You should be adding a drop or 2 of bleach/javex to the water every week or so to prevent the grown of bacteria in the unit. it will cut down on colds etc. hope this helps.
Oct 20, 2017 | Heating & Cooling
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
I charged my ac last summer, worked great. This summer the 2 vents on the passenger side work great, very cold. The 2 vents on the drivers side blow air but not cold, just like the ac is not on?
One of your Actuators inside the dash that control the A/C Heat doors/ Baffles that open or close, to either give you hot or cold air has failed. Find and replace the failed Actuator and it should work fine.
Jun 24, 2010 | 2007 Hyundai Tiburon
Driver's side defroster and heater vents blow cold air but the passenger side blows hot. Both sides should blow hot The temp is set any temp and it still does the same thing. It is winter so I don't know...
The doors that open and close in the heater control unit are ran by motors. It sounds like a motor has quit in yours. When turning on the defrosters the motor closes the door to the heat for the floor
Jan 12, 2010 | 1995 Cadillac DeVille
2004 sienna heating system problem. With the from heat control set to hot it sometimes blows hot and the cold air back and forth on its own with the heat set to hot?
try turning the blower down, if you have the fan on full you will feel cooler air from time to time. as the thermostat only measures the ambient tempreture inside the car when this level is met then it will turn off the heat so it will only blow the air from the car which will feel cooler.
if the car is still cold suspect the tempreture control in the car maybe faulty or the water level in the system maybe low.
Dec 02, 2009 | 2004 Toyota Sienna
Danby DPAC10061 portable air conditioner problem
you may have a factory defective unit that is not turning off the anti-frost heating coil (I have assumed yours contains this item based on your problem description). I would trade it in for a new unit, again assuming you have a warranty or the store offers a good in-store return policy. If this plan bombs, then open the unit and find the heating coil near the cool side of the radiator fins. then disconnect the power wires to the heater and prevent electrical short to wires with quality electrical tape.
Jul 06, 2007 | Danby DPAC8020 Air Conditioner
True GDM-9 Beverage Cooler Logo
286 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
