Question about Dymo LabelPOINT 200 Thermal Printer
Dymo label point 200
I need instructions on how to use dymo label point 200 can i please get a 1- 800 number for assistant
  • chch852 Aug 15, 2008
    I have a Dymo labelpoint 200, but no instruction manual, and would like to know how to change sizes, styles etc. Where can I access a manual from please?
  • Anonymous Aug 20, 2008
    I need an instruction manual for Dymo Labelpoint 200 Thermal Printer.
Dymo website, Support Tab:
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
    Problem Solver:
  • 7 Answers
type in LP200 in the search area. One of the choices is the user manual
Posted on Jun 11, 2008
I have a dymon labelpoint 200 but I don't have the user's maual. Where can I download those?
Posted on Feb 14, 2010
Enlarge font dymo handheld labeler
Please make sure the width of the tape is sufficient. You can select it every time you insert the cassette. If you would like step-by-step instructions, feel free to ring us (see for numbers).
Nov 18, 2013 | Dymo Labelmanager Lm 160 Handheld
Light is blinking and won't print labelsbet
If you like my solution, please give me 4-thumbs up rating.
Why is the light on the front of my Model 330 LabelWriter blinking?
There are 5 possible reasons for this:
  1. The labels are not left-justified
    • Verify that the labels are left justified and loaded properly in the LabelWriter. Click here for more information on loading the labels in the LabelWriter.
  2. There is paper dust or a piece of a label blocking the sensor
    • Take the roll of labels out of the printer and use the provided cleaning card to clean your unit. Click here for more information on using a DYMO Cleaning Card. You can also use compressed air by blowing some air along the left side of the paper path inside the printer.
  3. The labels you are using do not have the index marks properly cut out between each label
    • If the index holes are not cut cleanly, you may run into this problem. Try a different roll of labels.
  4. You are not using DYMO labels
    • If you are not using DYMO labels (or are unsure whether or not you are), please obtain a roll of DYMO labels and try to print again. DYMO labels are made specifically for our printers.
  5. The photo sensor that reads the index mark has failed
    • If this is the case, the unit will need to come in for repair. Select the Ask A Question tab at the top of this page to contact our Technical Support team. Please include the following information so that we can set up a Return Material Authorization (RMA) for you:
      • Full Name
      • Full Shipping Address (No PO boxes)
      • Phone Number
      • Date of Purchase
      • Model Number (a 5-digit number found on the bottom of your LabelWriter)
      • The 11-digit number under the barcode on the same label
      • Serial Number (located on the bottom of the printer, starting with "S/N" -- it also contains a dash after the first five numbers)
      • If your unit is out of warranty (beyond 2 years from the original date of purchase), please provide us with a method of payment (including expiration date, if using a credit card). The cost to repair your unit is either $75, which includes UPS Ground return shipping, or $90 for UPS Next Day Air return shipping. Please let us know which return method you desire.
Aug 04, 2011 | Dymo LabelWriter 330 Thermal Printer
Need instuctions for dymo label point 250 My manual is 12 pages long. Please put DYMO Manual as the subject and I will email it to you right away. Waiting for your response.
About Your New Labelmaker. With your new DYMO LabelPOINT™ 250
labelmaker, you can create a wide variety of high quality, self-adhesive labels. You can choose to
print your labels in many different sizes and styles. The labelmaker uses DYMO D1 tape cassettes in
widths of 6 mm (1/4"), 9 mm (3/8"), and 12 mm (1/2"). Tape cassettes are also available in a wide
range of colors.
Getting Started
Follow the instructions in this section to print your first label.
Connecting the Power
The labelmaker is powered by standard batteries or an AC power adapter. To save power, the
labelmaker will automatically turn off after two minutes of inactivity.
Inserting the Batteries
The labelmaker uses six 1,5V AA batteries.
To insert the batteries
1. Remove the battery compartment cover. See
Figure 2.
Jan 20, 2011 | Office Equipment & Supplies
We have a dymo labewriter that has a label jammed in the roller. Part of the sticky part is stuck on the roller. Cannot be pulled through. What to do?
LabelWriter Label Jam
  1. Unplug your LabelWriter.
  2. Remove the spool and labels.
  3. Remove the face plate.
    • Note: The face plate is the piece with the DYMO name/logo.
  4. Using the paper release lever on the left side of the printer, move the print head away from the feed mechanism.
  5. Straighten out a paper clip and GENTLY cut away at the label caught in the printer.
  6. Using caution, begin removing the label.
    • Note: We recommend using tweezers to remove the jammed label.
  7. Reinsert the face plate back on the LabelWriter. If you need assistance reinserting the face plate:
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 28, 2010 | Dymo Office Equipment & Supplies
We need firmware 93176vOT or 93491vOT - - - - - - - - - - - - - - - - - - - - - Dymo Labelwriter 400 Turbo bought in Europe with firmware blocked for use of original Dymo labels. We need firmware 93176vOT...
I couldn't find any information on the firmware version numbers, but I did find a site that might be able to help:
You might try to contact Dymo Support, on the same link.
Good luck, and hope this helps.
Sep 22, 2010 | Dymo LabelWriter 400 Thermal Printer
Found on WEB
Nov 12, 2009 | Dymo LetraTag QX50 Thermal Label Printer
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
DYMO Label/Writer is not printing after replaceing labels
DYMO labelwriters use patented labels, anything else would not be recognised by the system. For help - call DYMO support from your country.
DYMO support
Apr 03, 2009 | Dymo LabelWriter 400 Thermal Printer
Labelpoint 200
You can download the manual for the Labelpoint 200 here:
press the 'size' button, use the cursor keys to select the size and press enter.
There are only 2 sizes (small and normal) but these can be combined with 3 widths.
Nov 08, 2008 | Dymo LabelPOINT 200 Thermal Printer
Dymo 320 labelwriter downloadfor windows vista
Goto this page :
And click the 2nd icon along (XP/Vista Drivers), make sure to read the documentation before trying the driver as only some 300 series labelwriters are supported. If you specific model number (label on the underside of the printer) is not listed then it will not work under Vista.
May 14, 2008 | Dymo LabelPOINT 200 Thermal Printer
Dymo LabelPOINT 200 Thermal Printer Logo
1,854 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
