Question about HP PSC 2210 All-In-One InkJet Printer
Align cartridges again,again,again help
Do you have answer for fixxing problem?
  • 234 Answers
Unable to align Epson 3540 print heads
Hi, it is possible that the cartridge/s are not seated properly.
Try and remove them and reposition them again.
Sometimes this will work.
Also try turning the printer off and unplug it for a short time then retry installing the cartridges again.
then do a realine and see if it helps.
Regards Micky
Dec 12, 2013 | Office Equipment & Supplies
The Lexmark x5495 printer is not printing correctly. The printout is not aligned properly. The printout is crooked. How can you solve this problem?
Try to re-seat your cartridges and make sure they are properly inserted in the cartridge carrier.
If that doesn't help, please do the Align Cartridges function on your printer. From the printer operator panel, while on Copy mode, press the Menu button > Tools > Maintenance > Align Cartridges. You printer will then print a test page that will help align the cartridges.
After the page is printed, try to print a document again to verify that the problem is fixed. Thanks.
Feb 25, 2012 | Lexmark X5495 Printer
My Lexmark printer X2690 will not align properly after I' ve installed a new colour cartridge I have taken the security strip off! please help
You could try to remove and reinstall your color cartridge again.Do a Clean Cartridges cycle.Then do an Align Cartridges cycle.
Oct 26, 2011 | Lexmark X2690 All-In-One InkJet Printer
Every time i try to copy the screen says "press enter to align cartriges
Have you carried out a head alignment procedure, I would carry that out again
the online user manual is available from this link http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=79499&lang=en&
The HP PSC prompts you to align cartridges every time you install or replace a print cartridge. Aligning the cartridges ensures high-quality output. To align the print cartridges when prompted:
  1. Press Enter on the front panel. A page of patterns is printed. The cartridges are aligned correctly. Recycle or discard the page.
To align the cartridges at any other time:
  1. Press Setup.
  2. Press 5, then press 2.
  3. This selects Maintenance, and then selects Align Print Cartridges.
  4. A page of patterns is printed. The cartridges are aligned correctly.
  5. Recycle or discard the page.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | HP PSC 2210 All-In-One InkJet Printer
Everytime I switch on the printer,it starts alignment and prints a page
Try removing the two cartridges and power off unit.
Disconnect the power source and allow the unit to set for a few minutes.
Reconnect the power source and wait for error messages to come up on unit or computer.
Re-install the first cartridge and wait for the next message.
Again, insert the last cartridge and wait for the unit to acknowledge alignment procedure.
Answer yes to alignment and complete procedure.
After a complete alignment procedure, the unit should register the completion of setup.
Hope this works for you.
Happy Holiday's
John
Dec 09, 2009 | HP PSC 1315 All-In-One InkJet Printer
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
Mfc 845 will not with black ink. The ink cartridge is new. Will print in color. I ran it thru the cleaning cycle. Only prints the top half of sentences.
This sounds like an alignment issue. Please refer to this support artilcle and follow the instructions given there to align the cartridge. You may have to reseat the cartridge, by carefully following these instructions. Make sure the lock release lever is firmly engaged. (clicks).
Otherwise, you have as mentioned cleaned the print head, though you could try cleaning again if the alignment doesn't correct the error. For other support help, please see here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Oct 09, 2009 | Brother MFC-845CW InkJet Printer
Aligning cartridges, please wait
Pressed ok more than once to start alignment??
Have you worked through this page already? And you tried the "Bypassing the print cartridge alignment" solution? See HP's solution here. Make sure you don't have photo paper or colored paper in the input tray when aligning...
When you perform the reset, did you unplug the data cable (usb) as well as the power, and wait a few minutes? Try leaving both data and power cables unplugged for 1/2 hour and then resetting, and make sure you complete the power cycle by pressing start copy color. Link here.
If none of these steps work, try removing and reinstalling the cartridges, and if that doesn't help, here's a last ditch fix that may work in your case.
Otherwise, I'm afraid service is the answer...
May 23, 2009 | HP Officejet 5610 All-In-One InkJet...
Align page message
I have an OfficeJet 5780 and I have to do the alignment also. The allignment page it prints should have instructions on it. Just put it in the scanner and press "Enter". It needs to scan it to align the print heads.
This is from the manual on their website:
The HP Officejet prompts you to align cartridges every time you install or
1 Press Enter on the front panel.
An align cartridges (test pattern) page prints.
2 Load the align cartridges page face down in the ADF between the paperwidth
guides and press the Enter button again.
3 Recycle or discard the page.
Geno
Feb 21, 2008 | HP Officejet 4110 All-In-One InkJet...
Alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Dec 30, 2007 | Apple HP Officejet G85xi InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
