Question about Emerson CKA1000 Clock Radio
My cka 1000wants to display 20 ne most of the time.
My cka 1000 keeps displaying 20 ne. I reset the time zone and it works from a few hours to a day or so then goes back to displaying 20 ne.
  • Herje Jul 22, 2008
    Our clock did the same thing. Suddenly it displays 20 ne for no apparent reason. Don't know how repeatable it is yet. We lost the manual and had some trouble knowing how to get out of this display in the first place - and then actually set the time zone again
The manual recommends pushing the time / set middle large button once or twice. Have the antenna as far away from the clock as possiable. In the NE NY & Boston it make take a few days due to weak signal. It helps if the antenna is by a non metal window sill. If that doesn't work put it on the west side of a house and after a few days it will set. After pressing the button one of 4 dashes will appear in the display. This means it has confirmed the signal and the clock will set. ( I just found my missing manual and reset it all myself).
Posted on Jul 27, 2008
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Apr 29, 2014 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Can not change time zone on sharper image model lm521 projection clock
I got to liking the Sharper Image LM521 Digital Clock so much that I finally took the time to figure out how to manually set it-it was that or toss it! The instructions are as follows:
NOTE!!!
AFTER installing fresh batteries, or removing and reinstalling the batteries:
Successively pressing the "SET" button results in steps 1.) to 11.) below, each of which describes the particular/specific LM521 clock function you you can manually set.
HOWEVER, pressing the "SET" button after the clock had been previous set and running, will start the manual clock settings from step "2.)," "SET Offset Hours..." To start from step 1.), remove and reinstall the batteries.
PROGRAM/MANUAL SETTING MODE
After inserting the batteries:
The whole LCD screen lights up showing the different settings, etc.
After several seconds, the LCD screen clears and displays:
A flashing antenna
Upper left hand side of the LCD display. USA Time Zone Map
Middle right side of the LCD display (if necessary, to see, remove and reinsert batteries).
WAIT FOR AUTO TIME SET
A flashing antenna
> This indicates the clock is trying to auto set the time according to the WWVB radio/satellite time signal. Set on windowsill for best chance of success.
If it can't detect the signal, mannual setting is required, starting with the time zone.
> Manually set time ONLY if you are absolutely certain the WWVB signal cannot be found. Otherwise any manual time setting will be auto set to the WWVB time when its signal is detected, which may be many hours later.
SET USA Time Zone
1.) Press "SET" -- US time zone
> press "MODE" repeatedly until the desired time zone is reached.
5 = Eastern standard time (default setting)
6 = Central standard time
7 = Mountain standard time
8 = Pacific standard time
9 = Alaskan standard time
SET Offset Hours to Compensate for Satellite Signal
2.) After step 1.) above, press "SET"
A flashing "-7h" (minus 7 hours, default) and flashing USA Time Zone map appear.
This default setting worked just fine in New Mexico, MST, and may also work for your time zone as well.
> Press "MODE" to set from "-0" to "-12h" (minus 0 to 12 hours).
> Set to "-0h" if the satellite time signal set your clock to the correct time for the US time zone you live in.
> Set from "-1h" to "-12" to offset the time set by the satellite signal in case it does not match the time in your time zone. (E.g., 3pm -1h = 2pm.)
> NOTE: The default setting is -7h. If the satellite signal resets the time, say to 9pm, the time displayed will be 2pm (9pm-7h)--but if it should display 5pm instead to match your time zone, then set offset to -4h. Hence, the need to correctly set the offset hours if the -7h default value does not work for you.
SET Daylight Savings Time (DST)
3.) Press "SET" -- DST (Daylight Savings Time)
> Press "MODE" to set ON/OFF
SET Time
4.) Press "SET" (5no = seconds)
"5no" displays, plus flashing bars for seconds (not minutes as it falsely seems).
> Press "MODE" to set from 0 to 60 seconds
5.) Press "SET" (set hours)
> hour bars flash > press "MODE" to set hours
6.) Press "SET" (set minutes)
> minute bars flash > press "MODE" to set minutes
SET Date
7.) Press "SET"
> press "MODE" set year
8.) Press "SET"
> press "MODE" set month
9.) Press "SET"
> press "MODE" set day
SET Week Day
10.) Press "SET"
> press "MODE" set week day, Mom through Sun (Mo is default)
SET Standard (12) / Military (24) Time
11.) Press "SET"
> Press "MODE" set 12/24
CEILING DISPLAY:
SET/ROTATE Ceiling Projected Time/Temp Position
12.) Repeatedly press button with four tiny arrows pointing opposite each other (rightside of "DSPL" button) until the Time/Temperature display on the ceiling is oriented how you want it.
SET Ceiling Projection Brightness, or turn off
13.) Pressing button with sun symbol (leftside of "DSPL" button) cycles ceiling display from off, to brightness levels 1, 2, and 3.
SELECT between Ceiling Projected Time, Temp or Both
14.) Pressing "DISPL" repeatedly cycles between M0 (time), M1 (temperature), M2 (time & temperature auto switch every second or so).
Jan 23, 2012 | Audio Players & Recorders
I have an Intermatic DT300CH, how do I set the day of the week?
Intermatic DT300 is same timer as Woods 59203 and GE 15091
Open following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
http://www.waterheatertimer.org/pdf/DT300-series-manual.pdf
To set days, look at #5 ... go down to step 3 where it says 'press the DAYS button to choose the day or groups of days..."
Apr 17, 2011 | Solar Intermatic Digital Lamp Timer
How to program a woods TD1000 indoor timer
Here's how to set Woods TD1000 timer
This is older timer with backup battery. Plug in timer to see if battery will work. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day ...newer timers each offer 7 day function with choices of each-day, week-day, or week-end programming. The wider choices with newer timers may explain why TD1000 instructions are hard to find
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 04, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
I have a model CKA-1000 with the 20 ne problem. Last night I pressed the time zone button like it said in the forum and the correct time popped up. This morning, however, it was back at 20 ne. I again...
It is asking for the time signal.Try moving the clock/radio to another area in the house. The atomic clock will pick up the signal from Boulder, Colorado is on a frequency of 60 kHz. Unfortunately house current 120 volt is also 60 kHz and may be interfering with the signal.
Hope this manual will help you out solving the problem
The CKA1000 series will have same manual.So you can use this manual for reference.
Click here downlaod manual1
Click here download manual2
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 08, 2010 | Emerson CKA1000 Clock Radio
My message recieved time is displayed wrong
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
THANKS
Jun 21, 2010 | Nokia 7210
Skyscan Atomic Clock WWVB
figure out where yu are north south west east zones on your map from where yu are , then pull battery again it should stop at for eight or twelve push time zone then set in a window facing your zone it should automatically pick it up shortly in awhile
sw i think it may stop at four also but then wait
Oct 14, 2008 | SkyScan 86709 Atomic Wall Clock
Won't display time. Error message 20 ne
It's not displaying 20 ne - It's asking for the time ZONE . . .
Jun 20, 2008 | Emerson CKA1000 Clock Radio
Dakota atomic wrist watch sold by National geographic
s1 is the top button and s2 is the bottem button
Feb 20, 2008 | Dakota 2786-6 Wristwatch
Emerson CKA1000 Clock Radio Logo
370 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
