Question about Intuit QuickBooks: Pro 2005 for PC
Problem in installing quickbook 2005 pro
I am trying to install the program on my PC with Microsoft XP operating system, a pop-up window asked me to download the flash player 7 from the web first so the program can install it. I followed the instruction, but the same message window pops up everytime when the install try to proccess. I wonder how can I solve the problem. Please contact me at gg_lulu@yahoo.com, thank you so much!
  • kellou Jun 26, 2008
    We were unable to download the Flash Player 7. Adobe wants to upgrade to 9. Any suggestions would be appreciated.
  • cendo122 Jul 27, 2008
    I was trying to load QuickBOoks Pro 2005 on my PC to open an old file, and though I downloaded the macromedia archive Flashplayer 7, restarted my computer I still get the same request popping up asking me to load FlashPlayer 7. How do I fix this?
I have Flash Player 9 as well and have been trying to open and it has been blocking me with Flash Player 7. Just found solution. On your computer you need to do this. Go to MY COMPUTER. Right click on CD with QuickBooks in it and click OPEN. Double click to open QBOOKS folder. View 'details'. Double click on the only thing in the folder that says QuickBooks (19,961KB Windows Installer Package). This will load the program without trying to load the Flash Player first. It works. Just did it.
Posted on Aug 11, 2008
  • 3 Answers
You were suppose swicth off your pc after dowloading your flash player 7.
Posted on Jun 11, 2008
I am installing Quickbooks Pro 2005 on my Windows 7 computer. I got past the flash error but encountered a fatal error when trying to run quickbooks. Any fixes?
Try this:
  1. Open the Program Compatibility troubleshooter by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.jpg, and then clicking Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, click Run programs made for previous versions of Windows.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Jan 22, 2011 | Intuit QuickBooks: Pro 2005 for PC
I can't reinstall my Pro 2005 because it asks for Flash 7 then the cd tells me it can't install it.
You're several versions behind with your QB Pro, and also several versions behind with the Flash Player you're trying to install.
If you're reinstalling because you upgraded your operating system version, this is likely the root cause. QB 2005 is not compatible with Windows 7; neither is Flash 7.
While you may be able to install the program using XP Mode, that isn't the most reliable way of running it. I recommend avoiding uninstalling the .net framework files and "back versioning" as a way of getting around it, because it is likely to cause problems with other functions.
You may be best off to upgrade your Quickbooks version.
Hope that's helpful.
Jan 16, 2011 | Intuit QuickBooks: Pro 2005 for PC
Opening QuickBooks Pro 2009
Sounds like your re-installation of QB did not update your registry files properly.
I would suggest:
1) make a backup of your data
2) uninstalling QB
3) delete the QB installation folder entirely
4) re-install QB
5) restore your data
If this doesn't work, I can provide "remote desktop support" to try a more comprehensive approach.
Jan 27, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
How can i make quickbooks 2005 run on a vista laptop?
Here is how to load and activate Quickbooks 2005 on Vista...
First of all, if you already have an activated copy of QuickBooks 2005 on another computer open it and go to "help" "my license information" and print this out so you have the details needed for activating your reinstalled copy (you don't need a fresh activation key and you may have trouble getting one as QuickBooks 2005 is no longer supported by Intuit).
On your new Vista computer, insert the QuickBooks CD but cancel any program install windows that pop up. Go to my computer and find setup.exe on the CD, right click and select the option to "run as administrator"
Once installed, navigate to the QuickBooks folder on your hard drive (typically C:\Program Files\Intuit\QuickBooks) right click on QB32.exe and on the compatibility tab select both Disable visual themes" and "run as adminstrator". Now open this file to run QuickBooks and select "file" "Update QuickBooks" to download and install all updates. QuickBooks will not work properly until you have downloaded the updates, closed and reopened the program.
I had problems with activation but I got around this by unplugging my network cable so that I had no internet connection. If you run QuickBooks without an internet connection, when the screen pops up asking you to "activate" click next and the screen to enter your license details will appear. enter your details (printed out from your previous installation) and you are done. You can restore the internet connection and use QuickBooks 2005 normally.
Andrew
Jul 09, 2009 | Intuit QuickBooks: Pro 2005 for PC
Cannot open Quik Books 2007
Windows XP:
  1. Uninstall QuickBooks, Microsoft .NET Framework, and Microsoft Visual C++ 2005 Redistributable:
    1. Close QuickBooks.
    2. Click the Windows Start button and select Run.
    3. Enter control in the Open field and click OK.
    4. Double-click Add or Remove Programs.
    5. Right-click your QuickBooks program version and click Change/Remove.
    6. Follow the instructions to Uninstall QuickBooks.
    7. Repeat steps d through f to uninstall Microsoft Visual C++ 2005 Redistributable.
    8. Repeat steps d through f to uninstall Microsoft .NET Framework for your version of QuickBooks:
      • QuickBooks 2008 and 8.0 and later:Microsoft .NET Framework 2.0
      • QuickBooks 2007 and 7.0 and earlier:Microsoft .NET Framework 1.1
  2. Rename the QuickBooks program folder:
    1. Right-click the Windows Start button and select Explore.
    2. Browse to C:\Program Files\Intuit.
    3. Right-click the QuickBooks folder for the version you just uninstalled (for example, QuickBooks 2008) and select Rename.
    4. Enter OLD_ at the beginning of the folder name and press Enter (for example, OLD_QuickBooks2008).
  3. Insert the QuickBooks CD in your CD drive, and follow the instructions to install the program.
  4. Open QuickBooks.
Jul 09, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Error on Startup for Quickbooks Pro 2005
You can find the repair feature in the control panel add/remove programs window.
Open your control panel, click on add/remove programs, scroll down to QuickBooks and click remove (it won't you will be prompted to either repair or remove). Have you disk handy in case it prompts you for it.
Jan 13, 2009 | Intuit QuickBooks: Pro 2005 for PC
Launch Quickbooks pro 2005 for first time with error
This usually indicates a bad registry in windows, where the admin accounts are damaged. You can try creating a new user with admin rights. If the problem persists, you will probably need to do a system recover on the laptop, setting it back to factory specifications.
Backup any data you want to save first.
Nov 14, 2008 | Intuit QuickBooks: Pro 2005 for PC
HELP DELETING QB 2005
This commonly means the Microsoft Installer settings for the program are damaged or missing. This is actually a fairly common occurance and can be a sympom of registry issues. Microsoft has an Installer cleanup tool that can be useful at http://support.microsoft.com/kb/290301. This usually resolves the issue. If you are still having problems, search the Quickbooks folder for a file called REBOOT.BAT. Run this file ( this re-registers the software with windows) then try the cleanup tool again.
Oct 07, 2008 | Intuit QuickBooks: Pro 2005 for PC
Trying to Delete QB Pro 2005
This is often caused by a broken Microsoft Installler reference, or registry issues.
First, try searching the QuickBooks folder for a file called Reboot.bat. Once you locate it, run it.
Try to uninstall.
If that fails, Microsoft has an Installer Clean Up Tool you can download and run,
If all else fails, you may wish to contact an Intuit Pro Advisor in your area to see if they still have a copy of the 2005 disk to reinstall and uninstall with.
Intuit QuickBooks: Pro 2005 for PC Logo
204 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Dan Shibata
Dan Shibata
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
