Question about Maytag Neptune MAH7500WH Front Load Washer
Control panel stopped working during cycle. Whole thing just went dead. Won't turn on. light bulb inside tub still storks
  • 25 Answers
Sounds like bad control board
may cost a couple hundred
Posted on Jul 09, 2008
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
The remote is not working
either a the battery went dead in the remote OR there is an interfering device that is causing it not to respond
May 15, 2012 | Westinghouse Oak Harbor 78705 Fan
Had a LD error and successfully cleared clog in waste water tank. Turned it on and pump worked perfectly to pump out water. Started a new cycle to test everything and things went wrong. First, the tub...
If the water keeps filling with the unit unplugged you have a bad water valve(or low house pressure)
If the unit does stop filling when unplugged you have a plugged pressure hose to the pressure switch or a bad pressure switch. To access you peel back the front emblem to remove a screw in the center. This allows you to raise the top to check the pressure hose. You can also find the end of the hose at the control panel to blow through it, should be clear when tub is empty of water. A hole in the pressure hose would also cause flooding. This hose connects from the bottom of the outer tub to the pressure switch in the console to control the water level in the tub. Unit will not turn on drain pump if it does not sense water in the tub......
good luck......
Apr 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Breeze's brake light went out. changed bulb, now whole tail light won't work.
sounds like you put the wrong bulb in, that will make it blink fast. re check
Apr 18, 2009 | Plymouth Breeze Cars & Trucks
''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Mar 26, 2009 | Dishwashers
Stops during cycle
you must reduce water on faucet
Feb 16, 2009 | Kenmore Elite 45986 Front Load Washer
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
