M-Audio Keystation 49E 49-Key Entry-Level USB MIDI Controller with Session Recording Sof Logo
Posted on Oct 29, 2010
I bought used M-AUDIO Keystation 49e. I couldn't check it, and later I found that a range from E2 to F3 doesn't operate. I opened the keyboard and found that something had been spilled on it. I cleaned it up but the problem persists. I believe that the block EK49.04.A04 (or a chip on it) is damaged. My question is: can I order a replacement for this part and where? Thanks.
2 Related Answers
A
Anonymous
  • Posted on Oct 24, 2007
SOURCE: Problem with "M-Audio 49e keystation"
The 49e has been a real pain--especially if you have previously used another M-audio controller on the same machine. I just spent 3 hours to get mine working on XP (with a Creative sound card). In summary--for my machine--Windows XP kept putting the old WDM driver back (vintage 2001), even though I installed the M-Audio. I had to finally use the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. After I go rid of the WDM drivers and replaced them with the 2 USB ones from M-Audio, my DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install. I don't know if this makes enough sense, but good luck.
Anonymous
  • Posted on Apr 28, 2009
SOURCE: M-Audio keystation 49e stopped working
JA user_offline.gif vbmenu_register("postmenu_31136", true); M-Audio Tech Support Join Date: Jun 2008 Location: Irwindale, CA Posts: 5,033 icon1.gif "I asked our repairs department and they said the problem is either the main board or the velocity board. You can order both boards from our repairs department and return the one that is not needed. The main board goes for $20 and the velocity board for $14. 626-610-2529, Mon - Fri, 9am - 5pm Pacific Time."
I just found this in the M-Audio forums. I've just called the number and left a message at M-Audio requesting a callback. I'm really hoping that tech support will have a solution for whatever is causing this malfuntion. . . I'll post here again when the parts come.
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
2answers
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 • Ovens
When I hit a key, it is off by just a millisecond. How can I calibrate my m audio keyboard?
who cares its just a millisecond and its just takes a while for it to load on the computer nobody actually counts the time it takes
The piano wizard software won't recognize keyboard
you should go to your  utilities --> audio midi setup and make sure your system is recognising your midi device. Play around with your midi settings, see if you can get something going.
Otherwise the problem maybe with the software clashing with Leopard. Double check on the manufactures website that their software is compatible with 10.5.6, or they may have an update for you.
Thirdly you could check if you keyboard is working correctly by opening garage band and making a new software instrument track, press record and see if you get any thing.
Good Luck hope this helps.
4helpful
2answers
M-Audio Keyboard 49e disfunctions after some time
Sounds like it might be a power supply issue. Unless it is mains powered.
Try removing all other USB devised. If that doesn't work its worth try a Mains Powered USB hub.
5answers
Buy a Mac, Then you won't have that problem.
3helpful
2answers
M-audio 49e
Youve gone through the settings to make sure it is sending and your computer is receiving on the same midi channel?
Top M-Audio Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
