Question about Danby DPAC8399 Air Conditioner
Help me find where i can buy these parts
The piece from the bottle at the back of the unit is missing., the small connnecting clip.
is there a place in repentigny to buy that part and adjustable widow/patio slider kit?
2 Suggested Answers
  • 10865 Answers
SOURCE: Patio Door Kit
look in the yellow pages under sheet metal fabricator
J.
Posted on Jul 04, 2010
I removed my run capacitor from my Jenn Air Refrigerator Side by Side Model Number JCD2295KEP and when it was reinstalled a small piece of plastic broke off the Capacitor when I clipped it back to place. ...
If the case is not cracked it should be fine. There is a chemical in the capacitor that could leak out if the case and cause it not to work correctly.
Sep 24, 2014 | Washing Machines
Thye washing machine drum bangs side to side and is very loud
It's one of two things, a weak spring, buy a new spring and place it on tyhe grooves, if the groove piece is missing then drill a small hole in the base of the washer adn insert the spring bottom there and insert the top part in the bracket, be careful as the base edges are sharp and will cut you if you slide your arm across it...or the piece that holds the tub on the transmission shaft is worn causing it to wobble from the groove in it.
Jan 28, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Rearview mirror repair-The mirror just came off in my hand yesterday, leaving a circle of black film attached to the glass. In the past, I've repaired one with a small metal piece that hold the entire...
The small metal piece is just glued to the glass , and is probably still in the mirror assembly. You can buy the "special " glue at any auto parts store.
Glue the metal piece on , then after it has fully dried you can slide the mirror back on.
Nov 08, 2009 | 2002 Audi A4
PROBLEM; Aqua Brass faucet that controls water to either the tube or shower has come apart. The problem is that the metal pull lever that is situated on the top of the faucet has come off. With that, the...
You are probably missing the clip that holds it together.
It may be easier to just replace the tubspout/diverter with a new one.
Most just screw off, some are mounted with an allen screw on the underside and use washers to prevent leakage.
Replacement time 15 min. Cost 12 bucks.
Rebuild the diverter and you may make several trips to the stor just to find tyhe right parts. You will still have an old diverter/spout. and take just as much time repairing it.
Sep 25, 2009 | Plumbing
Nothing works on my Pioneer P7500dvd after getting a new ribbon??
I recently opened my unit up and experienced the same problem. What I found is when I took it apart, I had to remove the gray portion that holds the removanle faceplate. It has two tiny screws, one on each side. When I removed them the piece flips up and comes loose except for the ribbon which clips in place with a tiny plastic clip that WILL BREAK if you remove it. You have to basically break it to get it apart. The ribbon is covered by a small silver plate that has two screws. Since the clip breaks, when you put it back together, you have to slip the ribbon in place and find some way to secure it. What I did, is i placed the ribbon back in place and placed a dab of silicon on the broken piece and placed it back in its original position. I then placed a piece of black electrical tape over it to hold it in place. The ribbon needs to be held down tight to work so I took about two inches of black electrical tape and folded it a few times, placed it on top of the broken ribbon clip and placed the metal cover on top of it. Basically when you put the srews back in placed it squeezes down on the tape, clip, silicon and ribbon holding it in place. I turned it back on and it worked. Hope this helps. Dan(Macgyver)
Mar 23, 2009 | Pioneer AVH-P7500 Car DVD Player
Voxtel Infinity X1: Missing Parts
Please get in touch with Mr Arun Singh on his cell no +91 967662399.
He is based out of Mumbai & should be able to help.
I csae you need further assistance you can also reach Mr Anil at Delhi.
on his cell no +91 9212294293.
I am availabe on +91 9972790222
Regards.
Shyam.
shyam@binatonetelecom.com.hk.
ssunder9@gmail.com
Jan 11, 2009 | Uniden Cordless Phone
Passenger door window off track
Is this what it lookes like? I found these at O'Rileys. I have the same problem.
gpi?id=340936745&thumbnail=true DORMAN/HELP - Window Guide Item No: 38480 $9.79 per Card checkmark.gif 1 Per Vehicle checkmark.gif 1 year limited warranty (View Details) checkmark.gif SASH KIT checkmark.gif FRONT & REAR addtowishlist.gif storebothheader.gif gi?id=52917.5142 gi?id=52924.5135 addtocart.gif
Jul 20, 2008 | 2000 Oldsmobile Alero
Missing small adapter part
Hi marshaw40,
I'd recommend you attempt to contact Garmin support to see if they can supply you with this part. Their phone number is 1-800-800-1020 (U.S.). If they are not able to supply the part by itself then you may have to purchase a new power cord for the unit.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 10, 2008 | Garmin StreetPilot C330 GPS Receiver
Thermador professional range model prds484gg dual fuel
We just had to fix ours. There are some videos on youtube to give an overview of clip types.
On ours, we pulled the upper long hook down to the lower hook, then slid the clip lock into place. It then looks more like a one-piece hinge unit. Tip the door back into place, lift up to the horizontal metal piece, then slide the clips back to the open position(tis did take a screwdriverto push them back)-so the two pieces become two pieces-once inside the door frame again.
Nov 04, 2007 | Thermador POD301 30" Pro Series Deluxe...
Danby DPAC8399 Air Conditioner Logo
55 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
