Question about Kyocera Office Equipment & Supplies
My Kyocera 1810 copier runs a heavy black line down the right side of any copies run through the document feeder.
    Scholar:
  • 130 Answers
Clean the glass near where the paper enter the glass
Posted on Jun 11, 2008
How do I get rid of the black vertical lines for the Kyocera FS1128mp?
make a copy from the document feeder and see if the lines are there. then copy from the platen glass and see if the lines are there. then print to it and see if the lines are there. if the lines ONLY occur when feeding through the document feeder then check the slit glass VERY carefully for debris like gel pen ink and whiteout or other stuff. even one little speck on the thin slitglass will appear as a line on a copy through the adf. if it happens on ALL tests. then it could be a scored drum, bad dv unit, secondary transfer, or fuser.
Sep 30, 2014 | Kyocera Ecosys Fs-1128mfp 30ppm All-in-one...
Black lines on copy only when printing but copying is ok i.e km 1650
If this only occurs when using the document feeder then you will need to clean the smaller glass that sits next to the large glass that you manualy place your documents. The document feeder scans the originals over the small glass and any ink ,whiteout that may be on the glass will appear as lines down the pages
Oct 24, 2013 | Kyocera Mita Office Equipment & Supplies
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
When i make copies a line appears on the right side of the copy. This problem does not occur when i scan to copy only when the document runs through the feeder
Clean the document feeder scanner glass. This is the much smaller strip of glass that is to the right of the large main glass. This strip of glass is used ONLY when using the feeder. So if you are getting a dark line when using the automatic feeder but not when laying a document on the glass then just clean the strip glass. 100% sure this is your problem. You may need to clean it several times as I have seen stuff get stuck to this glass.
Good Luck and Thank You for using Fixya.
Jun 02, 2010 | Xerox WorkCentre XD120f Copier
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
May 20, 2010 | Office Equipment & Supplies
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
I have a kyocera 1810 copier. it has a error a 400
Does this machine have an ADF ( document feeder) on it? If so, check the connect cable from the document feeder to the machine. Also check the connectors from the scanner PWB to the document driver PWB. ( these are the 2 boards that do the communicating , the machine and the document feeder). If this machine does not have a ADF the check the side covers/ doors and make sure that they are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
158 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
