Question about Konica Minolta DiALTA Di200 Copier
Minolta Di351 Dialta
Code CO500 is this fuser? How do I reset it>?????
  • 1 more comment
  • Jim Keysor Jul 21, 2008
    There is a soft boot, that will allow you to get into the service program. There is a small and I mean small hole, sometimes to the right side of the keypad, press apaper clip in that as you turn on the machine. this will get you into the service mode and one of the windows will show "troubleshoot, or maintenance, etc" this allows you to reset this fuser code. If it pops up again you have a bad fuser
  • Anonymous Mar 04, 2009
    can't print
  • Anonymous Mar 16, 2014
    where can I find a Fuser cooling fan motor for a di315
  • 167 Answers
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Posted on Jun 12, 2008
CODE CO500, what can i do ?
Posted on Jul 18, 2008
Code problam c0500
Sir/mam,
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
Jan 22, 2014 | Konica Minolta Minolta Di351 DiAlta...
Code c0510 in dialta 520 how to reset
open the front door, upper left small access cover remove. press trouble reset. if the code comes back do not reset problem with the fuser continue reset fuser can catch one fire the will ruin a perfectly good day. have the fuser checked out.
Feb 02, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
How to reset the co500 error code from my minolta dialta di250
First check the right side cover where the image unit is located. Check the two latches that latch that door are not broken especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel with go thru some screens when you see the screen with copiers on it on the left side of the screen in the middle you will see a small "." when dot appears touch 3 button. Then the machine will continue to the code screen. Press the utility button should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part continue reset without a technician looking at and or replacing it can catch on fire that would ruin a perfectly good day
For a new fuse try this site for a start
forf Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Sep 30, 2011 | Minolta DiALTA Di250 All-In-One Laser...
Minolta error code c0500
A C0500 code deals with the fuser temp. You maybe able to reset the code, by pressing the trouble rest switch. If it will not clear you will need to look deeper into the fuser unit. I don't know what model you have, so I can not go any further. Good Luck
Nov 24, 2010 | Office Equipment & Supplies
DIALTA DI 2510 CPIER DISPLAY CO500
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. You need to locate the small hole in the panel which has a small switch behind it. It is located just to the right of the panel reset button, over the edge of the panel. You need a small paper clip or a tooth pick to insert into the hole to activate the switch. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see the initial screen come up. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. Touch the "Trouble Reset" box to reset the code. Then turn off/on the machine. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Konica Minolta DiALTA Di200 Copier
Co500
May 26, 2010 | Minolta DiALTA Di250f All-In-One Laser...
Malfunction detected, code CO500 on our printer, model Di251.
my di2010 has a co500 code on it after someone tried to run a transparency thru it.
Jun 25, 2009 | Minolta Di251 All-In-One Printer
Error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
Mar 30, 2009 | Konica Minolta DiALTA Di200 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Error code c0500
open back coever then press reset switch from mainboard
Sep 26, 2008 | Minolta Di2510 All-In-One Laser Printer
Konica Minolta DiALTA Di200 Copier Logo
996 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
