Question about HP Compaq nx9020 Notebook
The computer does not seem to be charging up
The computer does not seem to charging up from the ac power pack - any ideas thanks
  • 191 Answers
I am a Dell Certified System Engineer(DCSE)
try taking out tthe battery and then try powering the system only on ac adapter connected
if it doesn't power on only on the ac adapter make sure that the port on the system where you plug in the ac adapter for any kind of bent or broken pins
if the port is ok then get your ac adapter replaced.
Posted on Jun 10, 2008
2 Suggested Answers
abhi_patil
  • 568 Answers
SOURCE: ac power pack keeps failing, wont charge battery
get the whole laptop checked by the service center
as if the batteries and the power pack are ok there might be the problem with the mother board
Posted on Nov 24, 2008
Asus1000ha flashes between AC Mode and Battery Mode
Based on your explanation I will try to answer your problem.
It seems you have a problem with charger regulator. When you plug your charger into AC outlet then this regulator will detect the current that flows through voltage sensor then the Vreg pole will command the regulator to open charging circuit.
In plain English: Your computer has a problem with power regulator IC which located near the battery poles.
Aug 11, 2017 | ASUS Eee 1000HA PC Notebook
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
Aug 01, 2009 | Dell Inspiron 1525 Notebook
Acer Notebook 4330 No Power/No Charge
If the Notebook is only 1 month old i suggest you bring it back and see if they will replace it. Most likely the problem (for how you have explained it) is that the DC power pin (inside the notebook) is either broken or not soldered to the mother board correctly.
Being only one month old this is probably a faulty pin or installation from the manufacturer so this should not be a problem for the place you got it from to replace.
If you do have problems I suggest contacting the manufacture immediately to see if they will replace it.
I hope this helped
Have a great day.
Jan 28, 2009 | Acer TravelMate 2480-2968 Notebook
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Ac power pack keeps failing, wont charge battery
Aug 22, 2008 | Compaq Presario M2000 Notebook
No power
Better to connect another AC adapter and check it.If ur laptop have Warranty then please take it from nearest Service centre.
Thanks,
Feb 12, 2008 | Tatung (TWNB12N01) PC Notebook
Dell inspiron 6400 battery pack problem
If your battery pack does not charge and power is being supplied by the AC adaptor to the computer then i would guess the cells are dead or maybe the connection to the battey has been damaged in some way. The best way to check is take it to a computer repair shop or spares shop and ask them to try it with a new battery if the same problem occurs then it is the connection or the ac adaptor. My solution would be try a new battery before you buy it to check if it is the problem.
Jan 29, 2008 | Dell Inspiron 6400 Notebook
HP iPAQ doesn't turn on
Failed battery pack most likely.
Jul 11, 2017 | HP iPAQ hw6510 Smartphone
HP Compaq nx9020 Notebook Logo
131 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
