Question about Toshiba Satellite A135-S2276 Notebook
Key 4 doesnt work
The number 4 key on the keyboard doesnt work and laptop makes a loud and continuous alarm sound upon restart and stop only if the keyboard is tapped hard.
  • tcstz Jun 10, 2008
    Have done that already. No Luck. Thanks anyway.
  • Toshiba Master
  • 2,794 Answers
Could be a bad keyboard. Should have a technician look at it.
Posted on Jun 10, 2008
  • Tim Babcock
    Tim Babcock Jun 10, 2008
    You might be able to find a refurbished keyboard on the internet and plug it in yourself.
    That should fix the problem.
Hello,my laptop HPCOMPAQ 6735S boots with a series of continuous beeps.Plz help me to solve this problem.In touch.
hi
1. make sure that any key is stick on the keyboard,
2. you will have to remove all key, one by one until the beep sound stop.
if the problem continue then, you have to open the case and disconnect the keyboard cable from
the laptop mainboard, close the case. Then use a mini or normal size USB keyboard
hope this helped you to solve the problem
May 28, 2011 | Computers & Internet
I have an emachine E627 laptop, Recently ******** keeps appearing randomly in text boxes over and over and when you boot up a high pitched alarm sounds continuosly. I have cleaned the keyboard and there...
Definitely sounds like a faulty keyboard. If a key is stuck, you will hear a loud continuous bebebebebebebebebebeep sound on boot up. You can try carefully prying the "*" key off and checking to make sure there isn't anything wedged between the key itself and the little plastic bubble. If you still can't get it to stop, you will have to replace the entire keyboard. A quick search on google reveals that you can pick one up for under $50, and laptop keyboards are generally relatively easy to replace (often it can be done with only a flat bladed screwdriver).
May 02, 2011 | Acer eMachines 520-2890 Notebook
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Keyboard on hp dv7-1130us stopped working
    This sounds alot like a virus i once had!
    try a system restore to the point before these problems occured. if that doesnt work run a full virus scan. If that doesnt fix the problem you may have to wipe the hard drive completly.
    Apr 26, 2009 | HP Pavilion dv7-1130us laptop
    My C Doesnt Work
    What you need is a new keyboard. Remember--they are basically anelectronic part (in this case a pressure-sensitive part) and theysometimes fail.
    You can get a replacement keyboard from Toshiba or use a place like National Parts Depot.
    You can reach them at
    http://www.nationalparts.com/load.aspx?file=home.npd
    Apr 22, 2009 | Toshiba Satellite Pro 4600 Notebook
    Letter
    The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
    Hope this helps.
    Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
    Toshiba Laptop Keyboard problem
    My Toshiba Satellite A45 S120 keyboard has a problem, some of the keys are not working. When you type it does noting. Sometimes when you start the computer, it continuously types the letter eeeeeeee. You can hit some keys randomly and this will stop, but if you start a program (eg. ms word) the same thing happens.
    Sep 05, 2008 | Toshiba Satellite A85-S107 Notebook
    How do I disable my acer laptop keyboard?
    hi, big quextions are good. thyings are more clear.. no probs buddy, the best way is to open up the top lid, and simply unplug the keyboard strip from the motherboard,, u will be fine.. let me know..
    Nov 25, 2007 | Acer TravelMate 223X Notebook
    Acer Laptop keyboard problem
    It sounds like you have a problem with your CMOS battery. I had a similar problem with another Notebook recently. The computer does not know its CMOS settings (including the BIOS settings) anymore since the battery is empty or damaged. When you enter the device selection (F12) it saves the information again so it can boot normaly now. I think you should get a new CMOS battery and the problem might be solved. Also the keyboard problem might be fixed with that - i also had keyboard problems with the Laptop i mentioned above when the battery was empty.
    Oct 06, 2007 | Acer TravelMate 2300 Notebook
    Toshiba Satellite A135-S2276 Notebook Logo
    102 people viewed this question
    Top Toshiba Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    joecoolvette
    joecoolvette
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
