Question about Berkeley Forge G-PH001PSS Open Flame Patio Heater
Berkeley Forge Outdoor Propane Heater Sunrise Model SR1001
I too am looking for parts - an ignitor, electrode & bracket for my heater.  Anyone know where to get parts?  Is company out of business?
  • 1 more comment
  • ofd266 Sep 03, 2008
    any new news on parts for these wonderful patio heater ?????? My heater will not hold the pilot light on it will go out before the heater will light :( any ideas ...... any one ????????
  • ronsch5199 Sep 06, 2008
    i have the same problem if ni hold a lighter by the thermo couppling it works fine but im pretty sure this company is out of business so i dont know where to get parts
  • del6793 Apr 01, 2009
    I have a similar problem only mine won't light at all.
I believe the company is out of business but I just got my heater fixed using a local gas service company. Took them a while to find a compatible thermocouple assembly but he found it so there is hope.
The unit works like new now except for the ignitor but not a big deal as it works fine to light the pilot with a lighter.
Posted on Jun 01, 2009
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Tip
Sunjoy L-PH 018PS Patio Heater pilot failure repair
What is likely happening is that the pilot flame cannot reach the thermocouple. This is usually caused by corrosion or other blockage of the gas to the area where the pilot lights. Thus resulting in a small flame or no flame on the side the thermocouple is located. Fix this by cleaning out the corrosion or other blockage in the pilot assembly. I have found that small spiders like to make their homes here which causes the blockage of the gas for the pilot. The pilot assembly has three parts to it. The ignitor electrode, the pilot light tower, and the thermocoupler. The ignitor electrode has a wire that goes from it to the push button ignitor. The pilot tower is located in the middle and has a gas line going to it from the gas valve (control knob). The thermocoupler stands next to and on the opposite side of the ignitor electrode. It also has a copper line from it to the gas valve.
Unfortunately, the Sunjoy you have, which is the same model of two I have to keep running, is difficult to service. Parts are not readily available either so be careful when you take it apart. They do not sell the individual smaller parts in this model and therefore make you buy complete assemblies.
To clean and service the pilot assembly, remove the screws holding the front plate on where your control knob is. Once that is removed you can see the back of the ignitor, it is black and has one wire coming from it leading up to the ignitor electrode. You will also be able to see the small gas line from the gas valve going up to the pilot tower and the small copper line from the gas valve to the thermocoupler. That assembly is what you need to get to, to clean.
You do that by removing the top canopy by removing the three screws holding it down. Once that is removed, remove the center nut on the heat exchanger (the part that heats up with all of the little holes). It is located on the top and in the center of the heat exhanger. Then remove the three screws that are located around the bottom of the heat exchanger that connects the collar to it. You should be able to remove the heat exchanger now. Tilt the whole heater2_bing.gif down and prop the neck on something so you can work on it.
If you look in the top you will be able to see small metal box covering the pilot assembly. This is held onto the pilot assembly with two screws. Remove those screws and carefully remove the box. Now remove the two screws that holds the pilot assembly to the collar (located on the outside of the collar). The gas and copper lines will hold it up. If you look at the pilot assembly from the top you will see one screw holding the ignitor electrode to the pilot assembly bracket. Remove that screw, unplug the wire from the ignitor and remove the ignitor electrode from the assembly. Be careful not to break this and I am having you remove it so that you do not break it.
Now remove the nut that holds the thermocoupler onto the pilot assembly bracket and pull it out of the bracket. The copper line will hold it up and be careful not to kink the copper line. Take a piece of sandpaper and clean the outside surface of the thermocoupler. Corrosion on the thermocoupler could cause it to fail which will cause the pilot not to stay lit. I have not had one do that yet but it could happen.
Now, remove the gas line from the bottom of the pilot tower so that the tower and bracket are in your hands. Put it down and put the heater back up straight. Hook up your gas and turn the gas on. Now, press the control knob on the pilot setting to make sure you have gas coming out of the gas line that feeds the pilot. You should be able to hear, feel and smell it. If not you have a regulator problem or an empty tank. Turn off your gas, remove it from the heater and tilt the heater back down.
Take your pilot assembly, you will see a circular top to the pilot tower that is held down with really small metal ears. Carefully bend the ears back with a needle nose pliers so that you can bend the top of the tower back. Only bend it back far enough to clean the inside of it with a bent wire and compressed air or something. If you look on the lower side of the bracket, above where the gas line is threaded on you will see a hole that goes all the way through the assembly. This hole regulates the pilot gas pressure and allows the gas to mix with the air before it burns. Make sure that hole is clear of debris and take wire or something and thread it through the hole up through the top side of the tower.
When you have it clean, reconnect the gas line, thermocoupler and ignitor electrode. Once reconnected and before screwing the assembly back to the collar, I set the heater back up right and reconnect the gas. I then light the pilot to make certain you have a good strong pilot light generously touching the thermocoupler. The pilot should stay lit after holding the button in for a few seconds. Do not turn the heater on past the pilot area without the heat exchanger on or you might singe your hair. If the pilot works the way it is supposed to, turn it off, disconnect your gas, tilt the heater back down and reassemble it following the intructions in the opposite manner.
on Mar 24, 2010 | Heating & Cooling
Tip
Ready Heater Model R40
Recently my ignitor broke on my keorsene ready heater. No one in town
had the part. I stopped at a local wholsale heating and cooling supply company.
I looked at there ignitors and came across a white rodgers universal
igniter. Took it home and installed it with no motification. Unit works great.
on Jan 19, 2010 | Heating & Cooling
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
I have a round vanguard propane heater model lpc25d and we need an ignitor dor it. can yu help
Not sure which part of the Ignitor you need so here are the 3 parts with part numbers, that make up the ignitor
These are the original DESA Part Numbers:
Ignitor Electrode Part # 097150-01
Piezo Ignitor w/Retaining Nut Part # 02445-01
Piezo Mounting Bracket Paart # 0975056-01
DESA Has been out of business for 3 years, but some parts are still available online through another company. http://www.desaparts.com/
Hope this helps you find what you need.
Feb 28, 2011 | Vanguard Heating & Cooling
Sunjoy L-PH018PSS Patio Heater Replacement Parts
What is likely happening is that the pilot flame cannot reach the thermocoupler. This is usually caused by corrosion or other blockage of the gas to the area where the pilot lights. Thus resulting in a small flame or no flame on the side the thermocoupler is located. Fix this by cleaning out the corrosion or other blockage in the pilot assembly. I have found that small spiders like to make their homes here which causes the blockage of the gas for the pilot. The pilot assembly has three parts to it. The ignitor electrode, the pilot light tower, and the thermocoupler. The ignitor electrode has a wire that goes from it to the push button ignitor. The pilot tower is located in the middle and has a gas line going to it from the gas valve (control knob). The thermocoupler stands next to and on the opposite side of the ignitor electrode. It also has a copper line from it to the gas valve.
You do that by removing the top canopy by removing the three screws holding it down. Once that is removed, remove the center nut on the heat exchanger (the part that heats up with all of the little holes). It is located on the top and in the center of the heat exhanger. Then remove the three screws that are located around the bottom of the heat exchanger that connects the collar to it. You should be able to remove the heat exchanger now. Tilt the whole heater down and prop the neck on something so you can work on it.
Take your pilot assembly, you will see a circular top to the pilot tower that is held down with really small metal ears. Carefully bend the ears back so that you can bend the top of the tower back. Only bend it back far enough to clean the inside of it with a bent wire and compressed air or something. If you look on the lower side of the bracket, above where the gas line is threaded on you will see a hole that goes all the way through the assembly. This hole regulates the pilot gas pressure and allows the gas to mix with the air before it burns. Make sure that hole is clear of debris and take wire or something and thread it through the hole up through the top side of the tower.
When you have it clean, reconnect the gas line, thermocoupler and ignitor electrode. Once reconnected and before screwing the assembly back to the collar, I set the heater back up right and reconnect the gas. I then light the pilot to make certain you have a good strong pilot light generously touching the thermocoupler. The pilot should stay lit haver holding the button in for a few seconds. Do not turn the heater on past the pilot area without the heat exchanger on or you might singe your hair. If the pilot works the way it is supposed to, turn it off, disconnect your gas, tilt the heater back down and reassemble it following the intructions in the opposite manner.
The ignitor problem:
It is probably corroded in the cap (which is also the switch) or inside the ignitor where the battery goes at the spring. Spray these areas out with WD40 which will clean the corrosion out and try it again with a new battery. If it does not go click click click when you press the button you may have to take the ignitor out. Unscrew the cap and then the little black plastic collar which secures the ignitor to the collar. This should allow you to remove the ignitor by turning and maneuvering it out of the collar past the gas valve. Put the battery back in and replace the cap. Press the button to see if it works. Be careful it may shock you causing you to squeal, cuss and likely drop the ignitor.
I just had one do this to me. For some reason the little black collar that secures the ignitor to the heater collar would not screw all the way in. This would not allow cap to fully screw on and therefore would not allow contact with the battery to the contact inside the ignitor near the spring. Tighten it up as best you can so that contact can be made when you press the button. I believe this is one part you can order from Sunjoy separately if you cannot get yours to work....Good Luck
Jan 09, 2010 | Uniflame 200209 Open Flame Patio Heater
Replacement ingnitor for Dyna-Glo RMC-FA,50A
grainger sells the heater maybe they can help but tell them your a company
Apr 14, 2009 | Century Tool 2320I Heater
My BLP42 Master Propane wont stay lit what can I do?
Here is a link to your owner's manual... http://12.153.20.74/manuals/122371-01C.PDF.
If your getting no spark, then check to see if the ignitor wire is disconnected or loose. Check gap (The gap should be set between the ignitor electrode and target plate to 0.71". Then, check to see if piezo ignitor is loose. Lastly, it may be a bad ignitor electrode.
If you need to purchase a replacement part you can contact Master Parts at 800-446-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Jan 18, 2009 | Master Heaters BLP375AT
Ignitor not working
Yes, electrode is also called as ignitor. Both are same.
May 15, 2008 | Amana AKS3040 Gas Cooktop
Heating & Cooling Logo
1,972 people viewed this question
Top Berkeley Forge Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Berkeley Forge Heating and Cooling Expert? Answer questions, earn points and help others
