Question about Brother IntelliFAX 4100 Laser Fax
Brother 4750e hi, i work in an office where up to 30 people are constantly faxing documents from 1 machine. we keep getting a message that says "poor line condition, memory full" Is this a problem with our fax line or machine. Or too many faxes going out at once? My vendors keep complaining of receiving blank pages.. thanks! Andrea
  • 4,737 Answers
This problem could be Phone line problem, or hardware failure or receiver's (the machine of the person whom you are sending the fax) machine problem and so on. First, let's check the line, if you have another Phone line, please dial from the number to your number, also, connect the currently connected line to a receiver and call a Land-line number, if the outgoing or incoming is ok, the proceed forward, otherwise, you telephone operator should check the line.
Sometimes, sending fax to a particular number doesn't work, to make sure, try sending a fax to another number.
If the line which is connected to the machine is extended from another machine such as Receiver, Switch, etc... unplug them and connect the fax machine directly to the Line.
It's also important to adjust the compatibility mode, to do this, follow the steps below:
  • Press Menu.
  • Press the up or down arrow key to select Fax.
  • Press OK.
  • Press the up or down arrow key to select Miscellaneous.
  • Press OK.
  • Press the up or down arrow key to select Compatibility.
  • Press the left or right arrow key to select Basic (for VoIP).
  • Press OK.
  • Press Stop/Exit.
If you place the scanning document/file on the auto-sheet feeder, you can help it pulling inside the passage or you can use the glass (flatbed) instead. Sometimes, this small mistakes with the sheet-feeder creates this problem. You can also clean the rollers inside the ADF (auto document feeder) passage.
If all of the above measure don't help, I would suggest you to call brother and seek their help. The rest is with mechanical or we can say hardware or firmware related issue. (use this form to contact Brother)
I wish you good luck.
Thanks for using FixYa.
Posted on Aug 15, 2010
    Novelist:
  • 158 Answers
The "poor line condition" problem may be eliminated by unplugging the fax phone line at both ends and plugging it back in several times to ensure good contact. The cheapest solution to the "memory full" problem is to buy an inexpensive back-up fax machine for sending documents only. You can program one machine to receive all incoming faxes, and use both machines for outgoing faxes. Fax machines start at about $29.95 at most stores. They can often be programmed as "master" and "slave" in order of priority, depending on the model.
Posted on Jun 14, 2008
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Turn off error correction mode for Brother 4750e
I found this video I have embedded below which claims to instruct you on how to achieve this.
Mar 13, 2015 | Brother Intellifax 4750e Laser Fax Machine
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Need to program to date stamp incoming emails
Hi Deanna, unfortunately it is not possible on this unit to have the date and time stamped as that is produced by the senders machine, this feature is referred to as the station ID on your brother machine.
Mar 26, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Speed Dial Setup on Brother IntelliFax 4750e
pdf.textfiles.com/manuals/FAXMACHINES/Brother%20Fax%204750e-5750e%20User%20Guide.pdf
Apr 03, 2009 | Brother Office Equipment & Supplies
Brother IntelliFAX 4100 Laser Fax Logo
544 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
