Question about HP Officejet 5610 All-In-One InkJet Printer
Sending faxes I can send but not receive faxes Error codes 223,232,252 I have it connected to a DSL phone line, but have the filter on
    Problem Solver:
  • 14 Answers
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50333&cc=us&lc=en&dlc=en&product=441125
Also sometimes using two filters piggy backed will work.
Posted on Jun 12, 2008
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Error #252
This is a poor fax line error. The line quality has noise or some issue causing the fax receive /or send to fail , often people use the same line for faxing and ADSL (telephone provided internet) and this will cause noise on the line. To fix this I have used a noise filter that came withe the DSL router from the Telco. sometimes ive even had to use two, one on each end of the phone cable before the line was clear enough to send and recieve faxes without a problem. If this is not your case, have the person sending the fax do one at a time or vice versa. Hope that helps you Gurvy
Sep 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can't receive or send fax
~ Configure Fax Settings ~ Check Communication under Fax Settings
drd: all ecm: off v.34: off dial tone detection: on RTA: RTA of the fax must be higher than the RTA of answering machine ~ Check the physical connection of the fax ~ line port must be connected to a phone jack ~ if you're using DSL (Internet), Use DSL Filter
Jul 06, 2010 | Lexmark Office Equipment & Supplies
Fax set up -I've used this model for years and now
do you have dsl filters installed? the fax should go to unfiltered line not the filtered dsl line.
Jul 17, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I lost my manual and would like help in connecting to phone jack
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Apr 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Our Epson Sylus CX9400Fax Series is not receiving or sending faxes. We have already done the phone call to India thing for 90 minutes. All settings were changed and tested. They are now back to factory...
Ok, here's a check list for you.
SENDING
Check the following:
  • Make sure the phone cable is connected correctly and verify that the phone line works by connecting a phone to it.
  • Make sure that your recipient's fax machine is turned on and working.
  • If you connected the Epson Stylus CX to a DSL phone line, you must install a DSL filter to the line or you won't be able to fax. Contact your DSL provider for the necessary filter.
  • If your phone line has static or other noise problems, turn off the ECM (Error Correction Mode) setting and try faxing again.
    Follow these steps to turn off the ECM setting:
    1. Press Setup.
    2. Select Fax Settings, then press OK. You see this screen:
    4. Select Communication, then press OK.
    5. Press cp_button_44_er.gif and select ECM. Then press cp_button_42_er.gif and set it to Off.
    6. Press OK.
RECEIVING
Try the following if you can't receive a fax:
  • To receive faxes automatically, make sure the Auto Answer light is turned on. To turn it on, press the Auto Answer/Space button.
  • Make sure paper is loaded.
    1. Press Setup.
    4. Select Communication then press OK.
    6. Press OK.
Mar 03, 2009 | Epson Stylus CX9400 Photo Printer
Error code 634 on Panafax UF-770
The receiving fax machine is turned off or not functioning. Try calling your cell phone.
Do you have a DSL phone line?
Nov 21, 2008 | Office Equipment & Supplies
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
