Question about Canon imageRUNNER 5020 Copier
Copy Orientation My Canon imageRUNNER 5020 automatically changes the orientation of its copies, cutting off the content being copied (regardless of how it is placed on the copy tray). Is there any way to manually set the orientation? I have tried changing the paper tray and everything I know to do. Help please!
  • Canon Expert
  • 1,326 Answers
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
Posted on Jun 12, 2008
Copier orientation is incorrect. We print or copy something "portrait" and the result is "landscape"
Check to make sure that the paper size/ orientation dial is correct for the paper in the paper cassette.
May 02, 2011 | Canon imageRUNNER C3220 Color Copier
The machine keeps changing the orientation when you place the papers to be copied on the glass. how can you pick the one you want?
enter additional function(*); on screen, select copy settings>auto orientation> off>ok.
switch off the machine and re start.
place original according to the orientation of paper in paper tray and make copies.
Feb 08, 2011 | Canon ImageRUNNER 3235 Black and White...
Our Canon imageRUNNER 2270 is incorrectly orienting the paper. How do we fix it?
You can turn off the Auto Orientation of the machine. Go to Additional Functions > Copy Settings > Auto Orientation > On/Off
Oct 27, 2010 | Canon imageRUNNER 2270 Copier
My copier is making landscaped copies from the top feed. How do I set it back to portrait?
Under user mode ( asterix key ) under copy sett. set. the auto orientation to off.
May 24, 2010 | Canon ImageRunner 3025 Black and White...
Can't auto copy odd sized pages.
you need to turn off "auto paper select", and manually select an appropriate size /orientation, because the sheets are close enough to a particular size (based on the sensor locations) that the machine is choosing it for you.
May 26, 2009 | Canon Office Equipment & Supplies
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Copy orientation
Basicly, the check is smaller then a standard LTR size paper. The copier will only see it as a standard size. You will have to put a standard size peice of paper behind that check on the glass so it will read a standard size of paper.... The copier will not know that you are coping a check... They are not that smart..... Good Luck
Nov 11, 2008 | Office Equipment & Supplies
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Printing Alignment
Is the paper cassette set to the correct paper size and/or the printer driver printing to the correct paper size? Sometimes this can cause the image to be offset.
Sep 12, 2007 | Canon IMAGERUNNER 3530 Copier
Canon imageRUNNER 5020 Copier Logo
208 people viewed this question
old marine
old marine
