Question about Sebo Automatic X1 Bagged Upright Vacuum
Sebo x1.1 - burning smell
My 9yr old sebo has died. Was working fine, but then went off quite suddenly. A strong burning smell (like hot oil / metal). Replaced the fuse in the plug (this fused at the same time) and it died almost immediately when switching on.
Took off the motor cover - strong burning smell near the motor. Does this mean it is finally dead? Is it worth replacing the motor or buying a new one?
thanks for the advice.
K
  • HooverDemon Jun 10, 2008
    Thanks for the suggestion. Not sure that it is a belt problem (unless the belt is slipping and the motor is overspeeding and therefore overheating?). But will check. (I replaced the brush belt a few weeks back and it's been working fine and shows no problems).
  • carogw Oct 18, 2008
    Spooky... our 9 year old Sebo X1 has also just died, in exactly the same way! I've taken it all apart and the brushes and motor look fine. Replaced fuse and again got smoke and burning smell while motor turned over slowly. Is this a brushes issue, or should I replace the whole motor?
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Posted on Jun 10, 2008
My Sebo vacuum cleaner has no suction. Roller spins. If I leave it on it starts to overheat.
take it to a repair shop
something is jammed in the impellers section or the motor is burning out
Jan 05, 2017 | Sebo Vacuums
I started vacuuming and the vacuum motor slowed down, then stopped. I smelled a burning smell. Then I discovered the next day that the bag bottom was wet and falling apart. Sebo X4 model
sucked up liquid goes with the air through the motor
that would cause the motor to burn out
with the current low cost of new vacuums , the repair /replacement of the motor would be close to a new unit
take it to an appliance repair shop and get a proper diagnosis and quote
Dec 02, 2016 | Vacuums
Burning smell and noise from vacuum
The roller head may be turning, but something could be rubbing and causing the belt to slip slightly. I'd remove the belt and beater bar and look for foreign material that is stuck
Jan 07, 2015 | Sebo ET-1 Powerhead White
What wrong with my vacuum?
I expect something is rubbing on the beater bar or belt. Remove the beater bar and belt and look for a paper clip, scrap of material, etc.
My 1 Year Old Sebo X4 was lowering itself to hardwood floor with no air gap. Sebo Support agreed with my repair shop that a new (blue) brush roller would fix the problem by replacing the 'worn" brush (same...
No not quite. For a start, the stiff bristles on the blue roller can last a few years before requiring to be replaced.
The SEBO sensor wheel adjusts to the height required - unless of course the microchip board has been tampered with. If it hasn't been tampered with. If the central wheel is excessively dirty then it could be that the SEBO isn't lowering the height properly. However, the X series is great at cleaning hard floors in general - i it is not designed for the brush roll to fully hit the floor, thus as you suggest crushing the bristles. It is designed, as you recognise quite correctly to skid across a hard floor lightly as there is a squeegee rubber strip built in at the back of the roller bar that scoops all dirt into the central vacuum path. The front plate also lends this job. You are not being conned - however check that the rubber squeegee strip has not worn away - SEBO do sell the strips and they are easy to slide into via the press release door at the side of the brush roll.
If the SEBO has died then its a possibility that there is a microchip function that gone wrong it. Some more information would be good to know here as it could be a number of things such as the cord cables coming away at the handle.
Oct 30, 2013 | Vacuums
Hi. I have a Sebo X1 about 12 years old. Last time I used it there was an unpleasant smell in the room but didn't seem to be coming from the Sebo. However I am now trying to use it and it doesn't work. The...
The unpleasant smell could have been the lifetime belt finally giving up. Also happened on our 13 year SEBO X1 Automatic due to my error of vacuuming up a rug with long loose strands! If you are good with a screwdriver, you can replace the drive belt easily enough - go onto You Tube - there is an excellent UK video showing how to replace the drive belt on the SEBO. There are two belts, but you will know which one has to be replaced if you remove the screws on the underside of the main floor head. Before you do anything, kneel on the floor beside the SEBO and press the main release button on the bottom of the front bin area just above the floor head. It may need brute force but when pressed, put on knee on the floor head gently and pull the bin upwards to release from the body of the SEBO. This unlocks the main floor head from the bin, making it easier to look at the floor head. See video: http://www.youtube.com/watch?v=AOPphVcZHYA
Sep 14, 2013 | Sebo Vacuums
Sebo Automatic X1 Bagged Upright Vacuum Logo
1,351 people viewed this question
Top Sebo Vacuums Experts
Nick Olsen
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
