Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Brushes do not turn - Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
    President:
  • 1,673 Answers
Check the brush block to see if the shaft that goes into the turbine broke off, replace brush block if it did. If ok, then the turbine may be clogged up, either clean it out or replace the turbine.
Posted on Jun 10, 2008
Brushes not turning, 2 inch piec on one brush in place, the housing is spinning but not turning brushes
Hello there! It sounds like you may need to replace your brush block assembly. Try turning that drive shaft connected to the middle brush. All the brushes should be able to do a full turn simultaneously. If the brushes get stuck and cant make a full turn or if all of the brushes aren't spinning together then your brush block will need to be replaced. To purchase a replacement brush block simply follow the link below. Hope this was helpful!
Search Results
Sep 22, 2014 | Hoover SteamVac F5914-900 SpinScrub...
F7441-980 brushes won't turn
Paul:
Turn the vacuum over and remove the foot plate. Check the belt and manually try to turn the brushes. If the belt is OK, the brushes need to be removed and the roller bearings at the end of the brushes cleaned (hair, fibers, dust,) I remove the roller bearings and shoot them with alcohol while turning them until they turn free, then blow the alcohol out and lube them with one drop of light machine oil.
Nov 29, 2013 | Vacuums
Bissell pro heat 2x healthy home brushes wont turn
Hey Brenda! Here's a link to troubleshooting steps for the brushes not turning.
http://www.bissell.com/FAQDetail.aspx?id=1128&cid=ccsocial
Jan 15, 2013 | Vacuums
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
Agitator brushes wont turn even after cleaning
the brushes will not turn even wen the switch is turned on
Aug 10, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Brushes will not turn
Look for something wedged between the belt and the turning components. The smallest thing can cause a lock down. Make sure hair is not wrapped around rollers causing it to tighten up at bearing sufaces.
Jul 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Brushes turning slow on Hoover F5881-900 steam vac
there is a part inside called the turbine which needs to be replaced or cleaned. Also clean the brushes.
Sep 28, 2007 | Hoover F5881-900 Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
