Question about Frigidaire FAC124 wall/Window Air Conditioner
Can a window air conditioner fit in an exhisting wall mount?
I have a old wall mount conditioner that no longer works. Would a window mounted air conditioner work and fit, obviously depending on the dimensions? Wall mounted ACs are so expensive.
  • 2 more comments
  • Huggs13 Jun 10, 2008
    Wall mounted is where there is a custome-fit hole cut into the wall, non-window. The unit fits in and the back of it sticks out of the house. I believe is an old way of installing air conditioners.
    The issue now is finding a unit that fits the dimensions: 17 3/4"H x 26" W
  • Dung Nguyen May 11, 2010
    never heard of Wall mount AC. And yes, an window AC will work.
  • Anonymous Oct 07, 2013
    I needed help with air conditioning installation in Rowlett TX, too. I didn't think it would fit.
The unit goes off and on and will not let us change the temp or anything else.
Posted on Jun 16, 2014
    Champion:
  • 230 Answers
I bought window AC (5000 btu) that fit 17 in. at home depot. made by Zenith. Keep in mind of your room size.
Good luck.
Posted on Jun 10, 2008
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Accessing filter in indoor wall mounted LG air conditioner R18AWN-NC9
You should just be able to pull the front up from either end. It just press fits on - finger tips either side - presumably a wall mount?
This will expose the filters which just slide out for easy cleaning. Make sure unit is off as it will blow all the dirt all over you.
Tap clean outside or hoover them.
Dec 01, 2016 | LG Heating & Cooling
When I try to turn on my LG wall mount unit it will not turn on
Does it give you a code? Try turning only one at a time to see if that works. I would like to help you but need more information.
Sep 18, 2014 | LG LWHD1800R Wall/Window Air Conditioner
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Can I mount a Samsung AC unit thru wall rather then window?
as long as the vents are completlyeyt covered. and cove rit in winter
Mar 15, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Thru the wall AC units(small)
If the Ac unit can not fit your window, you can put a wall unit, you don’t have to open the wall and mount a stable unit, you just need to buy a portable AC unit put on.
This way cost you not too much.
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Through the wall vs. window installation
window mount doesn't have to extend out on the back to clear the side /top intake vents because a window is about 2" thick,
but a wall mount has to have about 6 to 8 " clearing before the intakes vents can be exposed. you can't have your intakes buried in the wall.
in short if you see about 8 " of dead metal in the center area (just behind the window sill) then you can mount it in a wall as it will protrude far enough to clear the side /top intakes.
a sleeve just gives you a way to balance / attach to the outside wall
Jun 12, 2008 | Heating & Cooling
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
727 people viewed this question
Top Frigidaire Heating & Cooling Experts
Electrolux
Electrolux
Dan Webster
Dan Webster
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
