Question about HP Pavilion dv6000z Notebook
Laptop response time
My laptop is running very slowly. It takes almost 5 minutes just to get to the desktop when I turn it on. I can't remember the model number, but it's an older HP laptop that I've already added and extra card to.
    Problem Solver:
  • 7 Answers
Please specify the configuration of ur laptop.May be, there are a lot of viruses in ur computer.If at all u r using internet, make sure u have kaspersky antivirus and u update it and scan ur laptop.
Posted on Jun 12, 2008
New battery charging very slowly?
Power off your Laptop, unplug the power cable from the laptop as well, take the battery out and wait for about 5 minutes. Put the battery back in, make sure it is seated properly. Plug the laptop back in and power it on an see if that charges the battery quicker. If it doesn't you may have a bad battery, and I would contact the place you bought it and ask for an exchange.
Oct 16, 2012 | Compaq Presario CQ61-310US Laptop
How to prolong the life span of your laptop battery
Instructional steps
  1. 1Use the laptop on a hard surface. This allows proper air circulation and prevents overheating. Avoid using the laptop in temperatures over 80 degrees Fahrenheit.
  2. 2Remove the battery when using AC power. Once the battery is fully charged, there is no need to keep it plugged in. Residual charge drains the battery slowly, so when the battery isn't needed, take it out of the laptop and store it in a cool, safe place.
  3. 3Allow the battery to drain completely before recharging. This allows you to take advantage of the limited number of charge cycles the battery contains.
  4. 4Limit the amount of applications, programs and external devices used on the laptop at one time. Close anything that doesn't need to run. Multitasking causes the processor to run too hard, producing higher heat inside the laptop and draining the battery power.
  5. 5Use your laptop's power control program to automatically save power. Reduce the backlight on your laptop when it runs on battery power. Set the standby and hibernate modes for when you take breaks from working on the laptop.
  6. 6Store your laptop battery in a cool place. Avoid heat above 80 degrees Fahrenheit, direct sunlight and extreme cold.
Remember to leave your comeent abnd share your testimony by saying how helpful this tip is to you
on Oct 05, 2010 | Computers & Internet
When I turn the laptop on I get a message"HP BIOS update 512/512. States you must let it update and will take a few minutes. After completion it will not turn off, or let me out of the screen; and I...
Hi kenneth_whin, to see if you can fix the problem.
"Try doing a "System Restore."
Click on the "Start Button," paul7of9_50.jpg from the Desktop.
Next, click on "All Programs," scroll to find "Accessories."
paul7of9_119.jpg "Open the "System Tools." "
Choose, System Restore."
A 'scan will start to look for, "Last known time of a change in the Computer.
paul7of9_52.jpg "Choose to 'create a date' ie: "HP BIOS Update."
Important!: The System restore can take a {1} hour to run!
!Warning: Do not 'touch' the [Keyboard] for any reason."
Let the (Restore) run it's configurations.
paul7of9_120.jpg "Choose the Date "closest to the time of the 'occurrence'.
Or, go back to a "Date," before the " HP BIOS Update!"
Now, click on the [Next] button.
paul7of9_121.jpg "There will be a message,
"Do not "Turn- off the computer."
!Warning: "Use AC Adapter "only" when 'running the program."
The computer will then; "Shutdown and Restart."
"Lo-gin" if you have to; but!
!Attention: "Do not touch the Keyboard once the Desktop 'window' opens.
"Because the {System Restore}, will 'still be running.'
Wait! Until there is a *message:
"Restore of the 'system' was successful!
Important!: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" paul7of9
Mar 13, 2011 | Computers & Internet
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
My Laptop is "Acer Aspire 4736z"
save the files to disk, or external hard drive. and reinstall windows.
Mar 23, 2010 | Computers & Internet
When i turn on the laptop why does it takes so long to load up? and also when i click on my apllications it take 5 minutes or more to load up.....what hould i do?? it celeron
Hello. If your laptop is old it is slow because the solder in the circuit boards slowly fry over a period of a few years. The only fix is a new laptop. I personally but the cheapest one I can now days, under 400. and when it gets painfully slow I replace it.
Aug 02, 2009 | HP Compaq nx6110 PC Laptop
Monitor displays slowly after the computer starts.
try to turn off you screen saver just turn off power monitor to see monitor easy wake up after long time.if ok means windows screen saver have problem if still same look like is you monitor something wrong need to check
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
My toshiba satellite p200-140 laptop will not start up. the power button lights up but nothing else happens. it was working fine last night
My laptop had a similar problem. I left my laptop running and some time later when I went back to my laptop, it would not startup. The power light seemed to be on but the laptop would not function. I tried several things like pressing on the power key for some time without any success and also tried all sorts of alternate buttons and sequences.
I resolved the problem by first disconnecting the power cord then by removing the battery for 5 minutes. I then re-installed the battery then connected the power adapter.
As soon as I turned the power button 'ON', the laptop booted up again.
Hope this works out for you.
Sep 28, 2008 | Computers & Internet
Change router locaation
do factory reset of configuration settings then log in with the routers default credentials. then change settings to your liking with one exception: DO NOT USE WEP!!!!! At a minimum use WPA 1 personal (with MAC filtering if you know how.) WEP can be hacked in less than 5 minutes.
Dec 13, 2007 | NetGear WGR614 Wireless Router
HP Pavilion dv6000z Notebook Logo
43 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
